Powering junction block to a no power option camaro
Old Aug 2, 2012 | 08:51 PM
Chubb's Avatar
Car: 1985 Camaro Sport Coupe
Engine: 305 Carb
Transmission: 7004
Okay I've searched and searched on a way to power up a junction block on my 1985 camaro sport coupe but still can't figure it out. I didn't have any power options so I bought a power door from a junkyard, c238 junction block, new window motor, door lock actutator, and a power harness from an 86 z28. So my question is, how do I get power from the fuse block to the junction block? Any help is appreciated. Thanks.
Old Aug 2, 2012 | 09:25 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Powering junction block to a no power option camaro
if you are using the stock fuse block under the dash I believe there are several unused slots. You put a wire in there, run it to your new junction block's source, and then you will have to work out the grounds as needed.
I could be wrong, its been a long time since i looked at the empty spots on my GTA's fusebox.
Old Aug 2, 2012 | 09:28 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check your existing harness... The necessary wire may be taped up in it. If not, go to a J/Y and snip a couple. You need both the orange AND the pink ones. You will run the pink to an ignition-on source and the orange to constant-hot. With fuses, of course, or a breaker, in the case of the power windows.
Old Aug 3, 2012 | 12:07 AM
Chubb's Avatar
Engine: 305 Carb
Transmission: 7004
Thanks guys, I will try both methods tonight whn I get off of work. My ac has started to act up and I refuse to ride without my driver side window down and no tint to block the sun. Lol
Old Dec 15, 2012 | 10:01 PM
Chubb's Avatar
Engine: 305 Carb
Transmission: 7004
Just took it to the shop and decided to let them do it before I blow something up. Plus I got the spoiler break light wired in also.
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
InfinityShade
Aug 22, 2015 08:00 PM
stalkier
Aug 13, 2015 12:59 PM
