Dash lights out. no pwer anymore to them.
Old Aug 10, 2012 | 05:19 PM
Mailman818's Avatar
Car: 89 firebird bone stock for now
Engine: 2.8L V6
Axle/Gears: B.W 9Bolt 3.27 Posi
so the other day i was fixing my horns and when i finished i drove my car around and it was fine. coming home from work one early morning and i lost all the lights in my dash, ac controls, and shifter light. checked it in the morning and swapped the fuse. problem solved...... next night i turned my lights on and they worked. i shifted from park to reverse then lost my shifter light. then when i shifted from reverse to drive. i lost all of them. swapped the fuse then they worked. it ended up happening again and i put a bigger amp fuse(7.5) and it lasted two nights till it popped.
funny thing was i swapped all my dash bulbs and mini bulbs to leds for better light and lower power consumption.
now when i put a new fuse i dont get any light from either bulbs nor do i get power going to them from the fuse block. what should i check or no next? i do alot of night time driving and its important i have functional lights since i can never tell how fast im going and police here are strict on speed limit when they catch you haha. even in the night with no one around its hard to get away going 15 over.
any thing anyone can think of?
im thinking of getting some of those led strips and re wiring my whole dash lighting system. well at least the gauges ones since my other lights work fine. im not sure if theyre on the same fuse or not.
Old Aug 10, 2012 | 05:43 PM
Cat Amanigh's Avatar
Car: 91 RS
Engine: 305 topped w/ Summit Holley Clone
Transmission: 700R4, a placeholder for that T-56
Axle/Gears: 7 5/8, 2.73
Re: Dash lights out. no pwer anymore to them.
Chances are you've got a loose wire after the junction block, before the lights. Since it's only blowing while the lights are on, I'd guess past the switch. Check for damaged insulation and loose terminals everywhere between the switch and the bulbs.
Old Aug 13, 2012 | 05:04 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fuse Ruse
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe each side of the INST LPS fuse socket with the fuse removed, and the dimmer in the MAX position, and the marker lamps on.
Is there power on one side of the socket?
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Old Oct 26, 2012 | 10:11 PM
Mailman818's Avatar
Engine: 2.8L V6
Re: Fuse Ruse
Just got around to finally tearing up my dash and trying to find the problem.
i tried getting the voltage from both side by putting the black pin on the chassis and the red pin on the green and grey in the inst lps and i didnt get any reading with the parking lights on...
could my switch be bad? ill be going to the junkyard tomorrow since im in need of more 5amp fuses and could use another switch just incase...
Old Oct 29, 2012 | 04:26 PM
NINÅ's Avatar
Transmission: 765R4
Fuse Ruse
Yes.
If the headlights work, but you have no power on both sides of a good INST LPS fuse, the headlight switch is bad, or the wiring to it.
Happy Racing!
Make Noise, Turn Left, Repeat
Old Oct 29, 2012 | 09:05 PM
Mailman818's Avatar
Engine: 2.8L V6
Re: Fuse Ruse
Ok wiring to it. Sounds good. Thatll be my next thing to check when i can take my dash apart. Thanks nina
Old Nov 2, 2012 | 08:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Fuse Ruse
Um, it's a Bird. There is a remote dimmer assembly between the headlight switch assembly and the fuse, mounted to the passenger's side of the dash support by the steering column with 2 screws. That would be the next stop before the fuse and after the switch. Check for power at the green wire with the white stripe here to rule out the headlight switch dimmer being bad.
If this dimmer is bad, I have one I can't use anymore...
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
