VATS Question.....Fixed!
Old Aug 14, 2012 | 08:11 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I just replaced my ignition tumbler, the old one lost it's a ability to re-coil. I bought a new ignition from Autozone without the VATS, b/c I have already disabled the VATS on my PROM when custom tuning.
The car doesn't start. Is it necessary to have a replacement ignition that has VATS included, seeing that I already bypassed it in the program? Is the VATS connection still needed?
Old Aug 14, 2012 | 08:41 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VATS Question.....
Originally Posted by heat seeker
I just replaced my ignition tumbler, I have already disabled the VATS on my PROM when custom tuning.
When you deleted VATS in the tune did you also bypass the starter enable relay also controlled by VATS so VATS was totally deleted?
If not ,even though the fuel enable signal requirement to the ECM for the injectors was deleted in the tune , the VATS module may still have been reading your old key to operate the starter relay and now you have a non VATS tumbler it can no longer read the key resistor?
https://www.thirdgen.org/vats_passkey_system
Old Aug 14, 2012 | 08:55 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Nope, I sure didn't. I guess an easy fix is to just get the ignition with the VATS wiring included on the tumbler. I just didn't think it was needed since I disabled it via ECM......guess I was wrong.
Old Aug 14, 2012 | 09:19 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I think the Oz is onto something. It sure sounds like the SER is not closing since you do not have the original ignition tumbler with the original key anymore.
IF it is your SER, you can easily bypass it. Either by grounding it or by connecting the two thick wires. Just search here on the boards and you will find a lot of info.
Old Aug 14, 2012 | 09:31 AM
Car: 89 Formula
Engine: 383 SBC/HSR
I'm in the process of reading my researched threads right now. However, just curious.......what thick wires are you talking about?
Old Aug 14, 2012 | 09:58 AM
BigBadLou's Avatar
Engine: TPI
In this diagram, you can see the Starter Enable Relay in the lower right section.
The yellow and dark green wires are the think wires that the starter current flows through. You can connect those together and bypass the relay completely. Or you can just cut off the think dark green wire and ground it to the body.
Hope this helps.
Lou
Old Aug 14, 2012 | 10:13 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Got it.....thanks for your help. Will try this evening and post results.
Old Aug 15, 2012 | 07:16 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Grounding the relay to the frame took care of my problem......thanks for your help with this. I'm back up and running.
Old Aug 15, 2012 | 09:18 AM
BigBadLou's Avatar
Engine: TPI
Glad you fixed your problem.
And thank you for posting a follow-up. It helps others who search for their problem and are looking for answers.
Old Apr 9, 2013 | 05:28 PM
mikesz1984's Avatar
Car: 1984 z28
i know this is an old thread, but this just saved me alot of time and money, thank you to you guys. i jumped the relay and my car fired right up. Once again, thank you.
Old Nov 18, 2013 | 02:14 PM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Re: VATS Question.....Fixed!
where is the vats relay located?
I replaced my sterring colum on my 88 with a 86 non vats. It has run for a while just in the driveay but first test drive and it just cut off. it cranks and has fuel but wont fire. I think something simple died otr cut on. Could teh VAT even though no steering columen still be my issue?
Like to see if I can ground the relay
Old Nov 18, 2013 | 02:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Driver side kick panel. Remove that and its recessed into the body there. Lil green wire, ground that, no vats ignition passkey required
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
