all turn signals work except dash indicators???
Old Aug 27, 2012 | 02:28 PM
bulldogSS's Avatar
Car: Siverado SS, IROC-Z
Engine: 6.0/5.0
Transmission: 4L60E/T5
Axle/Gears: 4.10/3.73
to mark a long story short. when i bought my iroc the turn signals did NOT work. replaced the flasher and now everything except the dash indicators are working. anyone have any ideas?? thanks in advance Mark already checked the bulbs(194s) and they are fine.
Old Aug 27, 2012 | 06:03 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: all turn signals work except dash indicators???
Possibly a bad contact on the instrument cluster? Bad bulb socket?
You would need to find out whether the bulbs are getting any power with the instrument cluster seated in the dash. I know it is not easy but that's your best option.
Btw, if you had a bad ground for the dash indicators, the two turn indicators would glow dimly with either turn signal on (backfeeding the ground through the other side turn signal).
Let us know what you find.
Lou
Old Aug 29, 2012 | 04:21 PM
87rattler's Avatar
Car: 87 Iroc-Z28
Not sure if this will help, but it's quick and easy...I had problems with my turn signals (inside and out) and cancelling cam...took steering wheel off and the turn signal switch seemed loose...tightened the 3? screws and BAM..everything worked.
Caspar
Jun 19, 2016 11:19 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
