Headlight motor fun..
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
I decided to quit procrastinating and finally rebuild them. Every single bolt snapped off and will need drilled out. And I also brilliantly lost the little ball bearing from the end of the worm drive. Any suggestions?
Car: 1984 T/A
Engine: LQ4
top down solutions has a kit tht has everything you need to fix both headlights.
Posted from Thirdgen.org App for Android
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Headlight motor fun..
Not sure about the ball bearing, but here is a cheap fix that works. 3, 1/4-20 stainless hex nuts (7/16 hex) replace the plastic drive disc things that are now powder. Then drill out the broken bolt, pickup some long machine screws and nuts, 8-32 iirc? Could be 6-32 I don't remember. I used rtv for the gasket, keep in mind there is a drain or breather at the bottom so don't plug it with too much sealant.
Works great, cost me $2.00 to fix my headlights.
Axle/Gears: BW 3.23
Sorry, Guess I should have been more clear. I meant suggestions for replacing the little bearing on the end of the drive. I already have a new bushing kit. I miraculously managed to find the little sucker though. Motors are rebuilt and ready to go back in next time I can manager to fight for a free moment.
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
great!
fun job aint it! I used heater core hose .487 of an inch in diameter. works perfect and will not bust into pieces!
bad design flaw.. or designed for service calls. sigh...
Axle/Gears: 3.45, 3.27, 3.27
1992 Trans Am
May 10, 2023 07:19 PM
