What is this plug and where does it go?
Old Sep 1, 2012 | 10:13 PM
LT2803's Avatar
Car: 1987 Camaro LT
Engine: 5.0L Carburated
Axle/Gears: Stock
So I put a new transmission into my 87 Z28 with the 5.0l TPI and had to take apart some connectors behind the engine to get to the top bell housing bolts. Now on reassembly I cannot find where this one connector goes. It is a two wire two pin connector. The wires are Pink with black stripe and the other wire is black. Cant find the other half of this plug. The car also has no spark or fuel to the engine so I believe this plug has something to do with that. Any help would be great.
Old Sep 4, 2012 | 05:31 PM
LT2803's Avatar
Car: 1987 Camaro LT
Axle/Gears: Stock
Re: What is this plug and where does it go?
Nobody has any ideas on where this plug goes? Its a two pin weatherpack connector with on pink wire with a black stripe and one black wire.
Old Sep 4, 2012 | 05:48 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
maybe a pic would help somebody notice it? hope you get it figured out.
Old Sep 4, 2012 | 07:06 PM
LT2803's Avatar
Car: 1987 Camaro LT
Axle/Gears: Stock
Ill get a pic this weekend. Its for my neighbors car. Found alot on this site to help me figure out my no spark or fuel problem so maybe its something that has nothing to do with this plug.
Old Sep 4, 2012 | 07:58 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It could be the infamous "mystery plug".
https://www.thirdgen.org/forums/tech...g-my-87-a.html
Old Sep 4, 2012 | 08:07 PM
LT2803's Avatar
Car: 1987 Camaro LT
Axle/Gears: Stock
Thanks eseibel67 that helped alot. Now I can focus on other problem areas. I never found that post when I did the searches so I must not have searched the right thing. But anyways thank you so much.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
