relay amperage draw
Old Sep 4, 2012 | 09:55 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
relay amperage draw
Anyone know off hand what the amperage draw is to close the typical GM relays used for fuel pump, fans, and so on?
I know the cheap square autozone ones used in everything from fisher plows to fog lamps draw about .15A to close.
-- Joe
Old Sep 6, 2012 | 08:25 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: relay amperage draw
You are in the ballpark, my guess would be up to 0.25 amps.
But if you want a precise answer, you can always unplug one of your relays and measure the resistance across the coil to determine the current (use 14.3 V with a running engine for the calculation).
Hope this helps.
Lou
Old Sep 6, 2012 | 08:29 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hope this helps.
Lou
You know.. I should have thought of that... Sometimes I'm just stupid.
Thanks Lou!
-- Joe
Old Sep 7, 2012 | 08:38 AM
BigBadLou's Avatar
Engine: TPI
My pleasure, just trying to help out.
In my country, we have a saying: "more heads is better than one".
What did you find out? I am currently away from all my car toys (in the hospital) so I cannot measure mine. And the wifey sure would not know where to find a relay, how to identify the contacts or even how to measure the coil resistance.
thunder57
Nov 7, 2015 02:28 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
raymondandretti
Sep 27, 2015 06:43 PM
