wich wire controls the reverse lights?(on shifter harness)
Old Sep 20, 2012 | 07:16 AM
napalm368's Avatar
Car: 1986 iroc z28
Transmission: 700-r4
HI.from what i have read..the dark blue,and light green wires on my shifter harness control the reverse lights.please correct if im wrong. my question is,,wich wire.. Drk blue or Lt. green..activate the reverse lights when the car is put in reverse. Thanks for any help.
Old Sep 20, 2012 | 07:24 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: wich wire controls the reverse lights?(on shifter harness)
Drk blue or Lt. green..activate the reverse lights.
Both
One is power to the switch ( should have 12V on it with key on )
the other is power from switch to lights ( should have 12V on it when shifter in R )
Old Sep 20, 2012 | 07:43 AM
napalm368's Avatar
Car: 1986 iroc z28
okay. thanks for the reply. but wich of the two wires has 12v on it when the car is in reverse?blue or green? i need to know because im installing a back up camera,and dont want to splice into the one with 12v when the key is on. thanks.
Old Sep 20, 2012 | 08:25 AM
Junqueboi's Avatar
light green
Old Oct 20, 2012 | 08:26 PM
Cadaver Puncher's Avatar
Car: 92 rs daily driver work in progress
Engine: 3.1 , 204/214 cam
Transmission: 700 r-4, b& m megashifter
Axle/Gears: I want a posi with rear discs
Can the reverse lights be hooked up to a toggle switch?
Old Oct 20, 2012 | 09:43 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Not sure why you would want to ( have to remember to turn them off when going forward , ticket material )
but anything is possible
Just disconnect the wires at shifter and run to new switch
Old Oct 22, 2012 | 11:53 AM
The shifter I have keeps them on all the time.
Old Oct 22, 2012 | 04:43 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Buy a new switch for the shifter or check if it is adjusted correctly
eightsixseven
Dec 16, 2024 01:50 PM
camaro11j
Sep 19, 2018 08:49 AM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
