Tachometer and 3rd high mount brake light
Old Sep 23, 2012 | 03:43 PM
IROCLOVER4EVER's Avatar
Car: 1986 camaro
Transmission: 5 speed manual t5
I need to know which wire is which for the tach on my 86 camaro it has a 74 350 in it with a msd ignition hei distributor if someone could tell me the color of the wire for my tach that would be awesome or a way to check if its the gauge thats not working
Secondly the 3rd rear brake light at the top of the car wont turn on i think i may be missing the fuse for it if someone could tell me which one it is tjar would be of much assistance
Thanks for everything and if you can take a picture or video that would be perfect thanks so much )
Old Sep 24, 2012 | 10:04 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Tachometer and 3rd high mount brake light
The tachometer wire is white.
For the 3rd brake light, I would check the bulb(s) in the light first. It uses the same fuse as the standard brake lights in the tail lamp housing.
If you determine that the bulb is good but the light is not getting any power, it might possibly also be the switch on the brake pedal assembly.
Diagram here:
Let us know what you find.
Lou
Old Sep 24, 2012 | 04:11 PM
Car: 1986 camaro
Alright well its connected so why would it not work? Am i missing a fuse could someone take a picture of their fuse box so i can see what i should have could it be the gauge is not working or what
Old Sep 24, 2012 | 04:25 PM
BigBadLou's Avatar
Engine: TPI
Yes, it is very common for our tachometers to grow out of calibration or even quit working altogether. You could borrow another cluster and put it in to find out whether it is the wiring or the cluster.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 19, 2015 01:36 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
