starter wiring
Old Sep 23, 2012 | 06:26 PM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
starter wiring
I just purchsed a 91 camaro rs with a unfinshed carbed 350 sbc swap. While doing a quick inspection once i got it home, i notice there was only one wire coming from the starter motor and the big wire that goes to the battery terminal. Neither are connected anywhere. I am pretty sure i need more than just that 1 wire. can somebody tell me what other wires i need and where they connect to on the starter motor?
Old Sep 23, 2012 | 06:55 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: starter wiring
Later cars had the power feeds direct from the batt ; not the starter terminal as in earlier cars
Should only need the purple wire from key to the starter solenoid terminal
Old Sep 25, 2012 | 11:05 AM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
Re: starter wiring
are the wires from the starter that feed power to the car needed for the starter to spin the engine over? I have a +cable going to the battery from the starter and a smaller wire that is connected to the terminal closet to the engine. when i connect the smaller wire to the battery nothin really happens. The starter makes a noise like the gear is spinning but not coming out and conatcting the flywhel
Old Sep 27, 2012 | 09:09 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: starter wiring
That would indicate that the starter is faulty
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
Accerrito22
Aug 23, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
