1992 VATS headaches
Old Sep 28, 2012 | 06:55 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
1992 VATS headaches
Before anyone jump and say search for the answer I did search for it and found out that the VATS is a common problem in late third gen model so here is my story I have a 1992 Z28 that was converted to carb long time ago it was fine till it started to act up before a year or so when I try to crank it nothing happens sometimes it fires up right away and sometimes not even a click just now I was working on the carb I crank it over to let the mechanical fuel pump fill the carb and when I left off the ignition switch and give it little gas to start up the car wont even crank I checked few wires grounds connections everything seems normal and checked the fuse box everything is working here I know its another problem I searched for the answer and VATS was behind this as some members here have the same exact problem as mine the PCM with the wiring is long gone I didnt have this problem before or at the beginning of the converting so Im assuming its the VATS about to die,now I want to cancel the VATS forever is there a way? Or should I get hot shot starter wiring like the drag cars and hook it up? I want to have fun with this car but this problem wont let me and I never had the chance to look at this problem till now it happened to me
Old Sep 28, 2012 | 07:13 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 1992 VATS headaches
jumper/bypass the starter enable relay
Old Sep 28, 2012 | 07:14 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/forums/elec...o-rs-wont.html
Old Sep 28, 2012 | 09:46 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Ok this sucks I just tried to fire her up and it fires up !! I think when the security light was blinking before I cant remember but now it doesnt so should I just bypass the starter enable relay? I think I will put a pushbutton just in case it acts up on me again
Old Sep 28, 2012 | 09:51 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
By the way the neutral switch is bypassed long time ago it was purple wire with green wire I will check those wires again later they might be not contacted good
Old Sep 28, 2012 | 11:04 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Have tried to clean the resistor contacts on the key. Sometimes the key gets contaminated or oxidized and doesn't make good connection to the VATS circuit. It worked for me until I just did the resistor trick,(you must have seen how it's done through your search). But the best way is to get it programed out with a custom chip.
Old Sep 28, 2012 | 11:11 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
My Camaro is carburetor and I have taken all the wiring and ECU out so why a custom chip? If I run a hot shot bump switch from painless will this help me get over the VATS ?
Old Sep 29, 2012 | 02:03 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
The pellet in your key is worn and doesn't make good contact everytime you start your car. I took a fluke meter and got the resistance from the pellet in the key and went to radio shack and got the same value resistor. Take the resistor and put it inline with orange and white wire that runs to your ignition cylinder just under the dash. It has a black plug-in that you can wire the resistor into without cutting anything. Add a little black tape and you are done. I did this years ago and haven't had a vats problem since. When it locks you out I think you have to wait 13 minutes or so before it will re-set and allow you to try again.
Old Sep 29, 2012 | 02:08 PM
Engine: Lb9
Transmission: M20
Old Sep 29, 2012 | 02:11 PM
Engine: Lb9
Transmission: M20
just connect the purple wire too the green with white stripe wire at the starter interrupt relay pigtail. no need to install relay unless you are running into hot starter woes caused by excessive heat from headers and a old ford starter relay works great for that.
Old Oct 2, 2012 | 11:57 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Just now the security was on so I tried this method I learned from Corvette C4 owner lock the doors from the inside and let it be 10min or so I tried that and it worked
Old Oct 3, 2012 | 09:03 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Door switch has no connection to VATS or the starter
https://www.thirdgen.org/vats_passkey_system
As already noted , once the ECM is gone all you have to is bypass the starter relay and VATS is gone for good
no need for resistors
If that is done and you still won't start then you problem lies elsewhere ;
Ign switch , P/N inhibitor switch , wiring to starter solenoid , etc
Old Oct 3, 2012 | 10:03 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
So all I need to do now is bypass the starter relay?
Old Oct 3, 2012 | 10:17 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Can anyone tell me exactly how to bypass the relay I searched for it and cant figure out what exactly to do I will go now and try to find the relay
Old Oct 3, 2012 | 10:26 AM
Engine: Lb9
Transmission: M20
I posted on post #10, the relay is under the drivers side kick panel.
Old Oct 3, 2012 | 11:15 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
I opened up the driver side kick panel just now and I didnt find any relays for the starter I found two connectors I disconnected them and try to fire her up and it fires one of them was for lock and unlock the doors and the other looks like a relay but when I disconnected them both it can be fired, I remember along time ago I did bypass the neutral safety from the shifter it was purple wire and green wire will this effect the bypass starter relay?
Old Oct 3, 2012 | 05:09 PM
jerm5801's Avatar
why dont you just put a new tumbler and key in it? its a lot less of a headache than doing all of that other stuff..
Old Oct 3, 2012 | 07:38 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Wait a minute so my problem is the ignition key ?!! I tried another key and same results is it ignition key cylinder dying? Did anyone use non-chip ignition key cylinder?
Old Oct 3, 2012 | 07:54 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
https://www.thirdgen.org/forums/elec...-location.html
https://www.thirdgen.org/forums/elec...0-starter.html
If the key turns it is not your problem
but you could have a problem with the Ign switch which is operated by the key.
If it is out of position ( or faulty ) it won't operate the starter circuit when key is turned to start
Old Oct 3, 2012 | 08:19 PM
jerm5801's Avatar
the key could still be a problem regardless if it turns or not. If the resistor in the key is damaged or what not...
say your vats resistance is 12 ohms. if the resistor in the key has a higher resistance than 12 ohms, guess what. its going to turn and not crank.
Usually, 1 of the 2 wires coming out of the ignition cylinder breaks inside of the column, causing the car to not crank. your car sounds like it either has a wire thats really close to breaking, or the resistor in the key is messed up and intermittenly showing a higher resistance.
thats the easiest way i can describe this. I would honestly just get another ignition cylinder and a key. its not real difficult to change it out, but you'll need to know the resistance value of the key. Most dealers still have their VATS tester, I'm sure they could stick your key in it and figure it out for you.
Old Oct 4, 2012 | 12:15 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by jerm5801
I would honestly just get another ignition cylinder and a key. its not real difficult to change it out, but you'll need to know the resistance value of the key..
Why bother?
With the carb he has ,VATS is gone anyway as a anti thieft device so just delete the VATS operated starter relay and no more VATS related problems
OP still has not confirmed that he has a complete circuit from the Ign switch to starter terminal?
Old Oct 4, 2012 | 01:06 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
if you measure the resistance of the pellet you can a get blank key on eBay and get it cut at any hardware store.
http://www.ebay.com/itm/1989-2002-CA...edd289&vxp=mtr
Old Oct 4, 2012 | 10:07 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Why bother?
What does OP stands for? Anyway I tried putting the test light on the starter terminal and when I hit the key the light turns on that was my first test before doing anything
So should I just change the ignition cylinder key or bypass the relay? I noticed something about the ignition switch when you turn it counter clockwise to turn on the acce. It wont stay on that position it goes back to off but this problem was there since it was fuel injection back in 2006 maybe like some members said the wires about to get cut
Old Oct 4, 2012 | 11:14 AM
Engine: Lb9
Transmission: M20
op stands for original poster. check the solenoid purple wire with a volt ohm meter not a test light. you stated before you bypassed the neutral safety switch you wire contacts there maybe bad. you need to check the voltage and connections all the way too the starter to determine if you are dealing with a voltage loss from a faulty connection at the p/n switch or a vats starter interrupt issue , faulty or mis adjusted ignition switch or bad starter solenoid.
Old Oct 4, 2012 | 11:56 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Will check them later and get back to you,the car now starts fine from the first hit from the ignition key dont know whats going on
Old Oct 4, 2012 | 12:43 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
I checked the ohm on the keys one read 475 and the old key 477 and it didnt read directly I had to scratch it little bit with ohm meter then it read
Old Oct 4, 2012 | 06:49 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You are still missing the point.
With a carb , VATS does nothing for you car anymore so why stuff around with new keys / or the resistors/ yada ,yada.
Bypass the relay ; VATS GONE
Still doesn't mean you have solved what appears to be a intermittent problem with your wiring to the starter as already outlined by tunedperformanc in post # 24 above
Instead of playing around measuring your key resistance you should be metering the wiring from Ign switch to the solenoid to see where the fault(s) lie
As I already noted , the Ign switch itself may be at fault; not adjusted correctly or it's contacts worn
Old Oct 4, 2012 | 07:12 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i had a vats problem for two months and about drove me nuts....sad thing is that had it programmed out the computer and it was still giving me a fit...i just bypassed mine today with a resistor under the dash... u need to get a ohm reader and see what the values are in the key and get a resistor at radio shack with the same ohms.....there is a orange wire with two white wires in there... splice them and put the resistor in there and problem solved.... one less electrical problem to worry about...
Old Oct 4, 2012 | 11:49 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Not really ,
all you have done is fool the VATS module into thinking the correct key is being used.If in future the module or relay fail you will still have no start
Bypass the relay and anything VATS related is gone completely
Old Oct 5, 2012 | 11:41 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Vetteoz can you please tell me exactly what to do when I find the relay?
Old Oct 5, 2012 | 12:10 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Post #10 tells you. The relay is usually behind the driver's kick panel. Mine has gooey black stuff on it. If the relay is missing, then there should still be a connector, but somebody will have already made the modification.
Old Oct 6, 2012 | 08:54 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by afremont
Post #10 tells you.
Your wire colors may be different to those shown in the diagram above
In any case , at the starter relay there should be 2 thick wires and 2 thin wires.
Cut the 2 thick wires off the relay connector and join them together
Old Oct 6, 2012 | 09:55 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
This is what I wanted to know just connect the two thick wires nothing else should I do?
Old Oct 6, 2012 | 11:41 AM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Ok after searching for the relay I found one I believe thats the right one it has one thick green wire and one thick tan wire and two slim wires should I disconnect the relay and try to fire her up to make sure thats the right relay?
Old Oct 6, 2012 | 05:53 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I believe thats the right one it has one thick green should I disconnect the relay and try to fire her up to make sure thats the right relay?
Yes
Before you cut anything ;jumper the 2 thick wires together at the relay connector
Old Oct 6, 2012 | 06:11 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Dont touch the large wires.
Just cut the ground wire coming from the vats box to the relay a few inches from the relay, put a ring terminal on it and bolt it to the body.
Starter relay no longer vats dependent.
Old Oct 6, 2012 | 06:19 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Does anyone tried this way?
Old Oct 6, 2012 | 06:28 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
I've done it numerous times, mainly just to bypass the vats lockout when testing, or on cars with vats programmed out.
Old Oct 6, 2012 | 06:54 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Now Im confused on which way to go with !!
Old Oct 6, 2012 | 07:35 PM
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
So let me get this straight
Cut the ground from relay and connect it to the body this way Im keeping the relay for the starter and in the same time the VATS is not woking anymore?
Old Oct 6, 2012 | 07:42 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Bingo.
Old Oct 6, 2012 | 10:29 PM
  #42
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Appreciate the simplicity of your solution but if VATS is no longer in the car , why retain a item ( the relay ) that is performing no function and subject to failure? ( with age )
If the relay fails on the road he will still have a no-starter situation
Old Oct 6, 2012 | 10:33 PM
  #43
Engine: Lb9
Transmission: M20
K.I.S.S
Old Oct 7, 2012 | 04:21 AM
  #44
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
Isnt some cars needs a relay for starter? I've seen some cars wont crank till after few tries because of no relay and when they put one it cranks right away
If it fails on the road I will keep extra relays with me
Old Oct 7, 2012 | 05:37 AM
  #45
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I had to add a relay to my old truck (66 GMC). When the engine was warmed up, the truck wouldn't start. I'd have to wait about an hour for it to cool down enough. It wouldn't crank because the old ignition switch and wiring just weren't up to carrying enough current to pull the solenoid in once everything got hot. I ran a 14GA wire from the battery to the relay and from the relay to the starter solenoid. Then I connected the original start wire to the relay coil. The other relay coil is grounded. Starts every time no matter what. Pulls the solenoid in like new car now.
Sometimes an exhaust leak can heat the starter and solenoid up and cause a similar no-crank situation until it cools off.
Old Oct 7, 2012 | 05:51 AM
  #46
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Correct .
In some cars it supplies power direct from the batt to starter to reduce voltage drop.
In a VATS car it only functions as a means of cutting off the power to the starter for anti theft and with a carb you have already deleted the most important part of VATS ; the fuel cut off function
A half decent thief can throw a wire on your coil and a wire to the starter and be off with you car
Old Oct 7, 2012 | 05:57 AM
  #47
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
That's why I like my VATS. Bypassing the relay is a piece of cake, but supplying that signal to the ECM to make it pulse the injectors is a tough one for even the best thief.
EDIT: My car will not be driven away. Possibly even by me some day.
Old Oct 7, 2012 | 12:01 PM
  #48
92-Z28's Avatar
Car: 92 Z28
Engine: 350ci
Transmission: Th350
So what now? Should I keep the relay or not?
Old Oct 7, 2012 | 12:06 PM
  #49
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
It's up to you, you have several options available to effect a bypass of it. I'm not a fan of cutting the factory wires, so I'd probably remove the relay and install a jumper into the socket to connect the fat wires. That way it is completely reversable.
Old Oct 7, 2012 | 01:52 PM
  #50
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Indeed, however most people arent very good at wiring, and from a lot of experience i've seen that even most who claim to be, arent, so the likelyhood of a good solid reliable connection of the two large wires, isnt nearly a possibility as a reliable small ring terminal onto the ground wire, also the failure of the relay is a slim chance, do you go replacing your fuel pump and fan relays with house light switches because "its something else to go bad" too ?
