Starter motor wiring
Old Oct 2, 2012 | 02:11 PM
Chuck's Avatar
Starter was working fine, until i removed it to make a shim.
Now... nothing happens when the key is turned.
My starter motor has 3 terminals.
1 is to negative side of battery.
1 is to positive side of battery.
There is a smaller gage red wire to the positive terminal.
There is a smaller gage white wire that I didn't mark.
If assuming that goes to the small terminal on the starter, but when
I connect it there, nothing happens.
Any ideas?
Also, I put some grease on the custom shim as a rust preventative.
I assume that would not effect grounding.
Old Oct 2, 2012 | 03:00 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Starting Trouble
You can use an ohmmeter to make sure the starter is grounded.
Then:
As long as you have power to the Main terminal and to the solenoid, it should spin.
Happy Racing!
How Come Some Drivers On The Street Don’t Know How To Make A Turn In One Direction Without Starting By Turning In The Opposite Direction?
Old Oct 3, 2012 | 09:44 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Starter motor wiring
Is this for a stock 3rdgen starter? (your post or profile does not say)
Because the stock starter is grounded through the engine block and thus does not need a negative cable, as you mention. So make sure you have the cabling right, this does not sound correct (again, assuming a stock setup).
Old Oct 4, 2012 | 12:46 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
You may have put the little wire on the wrong post (been there done that) in which case when you hit the key it will do nothing since it kicks in the solenoid.
Old Oct 4, 2012 | 03:40 PM
Chuck's Avatar
You are correct! I brought it to my mechanic today (before seeing your e-mail)
Thing is... the other small post was obstructed from view.
I didn't even remember there were 2 posts.
Feeling pretty stupid.
Man... it is tough to be human sometimes!
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Oct 24, 2015 07:48 AM
L98GTA87
Aug 5, 2015 11:02 PM
