alternator valve covers clearance problem
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: alternator valve covers clearance problem
Yes, I believe that is doable. It's called clocking your alternator.
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
I dinged mine with a hammer...
And I still blew the chrome off that valvecover a few times while removing it, etc. stud was never covered with rubber or anything.
And I still blew the chrome off that valvecover a few times while removing it, etc. stud was never covered with rubber or anything. Joined: Jul 1999
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why did he take it apart? He should have just pulled the bolts and rotated it...
-- Joe
-- Joe
Car: 91 Camaro RS
Engine: 305 TPI conversion.
i recently had this problem. i had an old piece of hose runnning between the valve cover and alternator that may have been a contributor to the damage. it burned a hole in the valve cover, and burned up part of the plastic gasket behind the stud.
since repairing the damage i have not had another problem. im planning on changing out the serp drive for a v belt. im only running the alternator, water pump and p/s.
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I think some alts. are different. I was able to remove the bolts and turn the top, after I removed the pulley. I will post pics after I paint it.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Well that's sure a whole lot easier than trying to put the fiddly pieces back in. To be clear, there is only two pieces to the case right, front and back halves?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Unbolt, spin the front, rebolt.
-- Joe
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Also - disconnect your battery before doing any work that's likely to jam grounded metal things into your alt stud
. A rubber cap might be a good idea too.
. A rubber cap might be a good idea too. Re: alternator valve covers clearance problem
True but on mine 89' I had to remove the pulley first. I tried to just twist it but where the bolt holes are they extend down and hit each other. you can twist the top with the pulley on both ways but you need to lift the top about a 1/4 of an in to be able to change positions.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
http://store03.prostores.com/nookand...f28a141c_m.JPG
-- Joe
yes, but it was easy to remove the pulley. I wrapped a strap around the pulley and used a socket and wrench. It was actually dealt easy. I will take some pic and post when I get home.
NBrehm
Aug 25, 2015 11:49 PM
