VSS wires from dash
Car: 92 Z28
Engine: 350ci
Transmission: Th350
VSS wires from dash
So I found out that there are no wires under my car near the tranny for the VSS and Im already doing the starter relay bypass can I find the speedometer wires under the dash where Im at now?
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: VSS wires from dash
The vss wires are part of the engine harness and run from the tail of the transmission along the harness through the fenderwell area, and to the ECM, looking under the dash if you dont see the pigtail plugged into the transmission isnt going to help you right now.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
your profile says you have a th350 ? you said in your other post that it has been converted to a carb. if you are using the stock ip you will need to get a vss buffer and vss.
http://tpiparts.net/inc/sdetail/7586
Engine: Lb9
Transmission: M20
not all the wires will need to be hooked up on the buffer. you just need accessory power and ground to the buffer. signal and ground from a 2k vss and the 4k output from the buffer to the speedometer.
