Rear Hatch Upgrade
Old Oct 23, 2012 | 02:54 PM
Hupzer's Avatar
Rear Hatch Upgrade
I am currently in the process of restoring my 91 RS and am in need of some insight. Right now I just have a manual latch system for the rear hatch and want to install the motorized version. The previous owner has goobered up the bracket he installed. My question is where are the mounting holes for the new bracket assembly (pics attached).
Thanks in advance..
Hupzer
Attached Thumbnails Rear Hatch Upgrade-2012-10-22_19-29   Rear Hatch Upgrade-2012-10-22_19-29   Rear Hatch Upgrade-2012-10-22_19-39
Old Oct 24, 2012 | 12:24 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Rear Hatch Upgrade
OMG. I am so sorry for you. You'll need to rip all that out and weld in the mounting bracket from a late 91-92 car. Those years have a pull-down with a tan-colored molded plastic frame.
Lon
Old Oct 24, 2012 | 01:49 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Lon
He will need to determine which came with his car, the early 91, or late 91-92 setup before doing so.
Old Oct 25, 2012 | 12:12 PM
Topspeed's Avatar
Car: '84 Firebird
Transmission: 700r4 with kit
Axle/Gears: BW 3.73 Posi
Lonsal is correct. I just did this on my '84 Bird. Converting from non-motorized to motorized. I found a motorized unit out of an '89 formula, drilled out all of the spot welds, and rewelded it to my bird. Not to hard of a project but drilling spot welds sucks. Good Luck
Old Oct 25, 2012 | 12:38 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Again, OP before jumping into what wont work, because your car is a 91 you need to first determine which hatch motor your car came with factory, then get the appropriate bracket.
And to answer your question about the holes for the bracket, there are none, the bracket is spot welded to the body from the factory.
Old Oct 25, 2012 | 03:31 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Does it really matter? Since he has to replace the bracket, shouldn't he be able to use either style?
Old Oct 25, 2012 | 10:17 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Yes, it does matter, I wasnt just posting because the keys on my keyboard needed testing.
Old Oct 26, 2012 | 12:31 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Please test your keyboard further and explain. I am thinking like afremont is in that either bracket will work since you have to buy a motor anyway and then wire it up. And you could probably find bracket, motor and wiring complete for an easy swap besides the spot weld drilling.
Old Oct 26, 2012 | 02:04 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
The tail panel that the taillights and lock cylinder attach to is different on the late 91/92 cars the lock cylinder is in a different location.
So no, you cannot just swap the bracket and be done, and I wouldnt put the spot weld drilling down as a small feat either, there are a LOT of them.
If you havent got the hint, i've done this, or rather attempted it, after drilling out every one of the spot welds on the early 91 car to remove the bracket, drilling all of the spot welds to remove the bracket from a 92, and then using rivets to install it in place temporarily to hold it for welding, discovered that the lock cylinder isnt going to lineup and allow the motor to bolt up, and it would have to be relocated if this were to work.
Old Oct 26, 2012 | 07:58 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I was just wondering what the special thing was that would prevent the other bracket from working since it has to be changed anyway. I guess the hatch itself must have some difference, since I sure don't know of any body difference that prevents using either bracket.
EDIT: Never mind I see the post now. So the body is different then. I wonder why.
Old Oct 26, 2012 | 11:23 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
It interfered with bolting the motor on (the lock cylinder), so i'm guessing they redesigned the whole back panel to relocate it, not quite sure how they didnt just design the new setup around it.
Technically it can be done, you'd just need to get a section around the lock cylinder from the back panel, carefully cut out the original and weld it back in.
I just called the waste of time a loss then, and put the earlier 91&earlier bracket back in the car.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
