Fog Light Hidden Switch
Old Oct 28, 2012 | 03:38 PM
hbj306's Avatar
Car: 1986 Trans Am
Axle/Gears: unknown...help?
So I don't know if this has happened to anyone else, but my fog light switch wasn't working right. They would light up if i kept my finger on the switch, but they wouldn't stay on by themselves. So I decided to wire in a new switch, but keep the old one there for looks. I went to radio shack and bought a $3 SPST switch and a $3 pack of spade connectors, and took apart the left underside of my dash. If you look at the back of the switch, there are 5 lugs that plug into a plastic connector. All you have to do is take two pieces of wire and stick them in the connector so they contact the lugs of the brown and yellow wires, and then connect the other ends to the SPST switch. Drill a hole in the plastic plate to mount the switch,and you're done! Works like a charm.
Old Oct 28, 2012 | 04:23 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Fog Light Hidden Switch
Why not just replace the stock switch, it's obviously broken.
Old Oct 28, 2012 | 11:08 PM
hbj306's Avatar
Car: 1986 Trans Am
Of course it's broken. Did i not mention that? I chose not to replace the stock switch because I took apart my existing switch and realized the point of failure is a weak point in the design. So rather than shelling out 25-30 bucks for a USED switch that might fail tomorrow, I made my own switch for way less initial cost, and this one will probably last a good long time.
Old Oct 29, 2012 | 03:02 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
my car is ~25 years old and it still works perfect. But you do what you think is best.
Old Oct 29, 2012 | 01:52 PM
hbj306's Avatar
Car: 1986 Trans Am
Congratulations on your car's perfection! Mine, however, is not, so I did what was best. However, I appreciate your approval of my creative license.
Old Oct 29, 2012 | 02:58 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
My point wasn't to criticize your fix but to point out that your switch going bad wasn't that common and that just replacing it with a new one would probably be a better solution.
jaridjohn
Jul 8, 2024 03:49 PM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
