starter problems
Old Nov 30, 2012 | 02:37 AM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
starter problems
Hi guys so I'm having some starter problems basically here's how it went. The starter that was in the car when I bought it was doing great. Until about two months ago it started clicking multiple times and then finally stopped I took out the starter and the battery and was told the battery is good and the starter is bad. I put a new starter in and the clicking was still there but it would start. Now about a month later the new starter has stopped clicking I have warranty on my starter I just wanna fix the clicking it would take about twenty clicks. Reason I didn't solve it during that month was because I was having a issue with vats but I installed the bypass and it was working finer but Stoll clicking any help would be great. Sorry for the long story or spelling errors I'm on my phone
Old Nov 30, 2012 | 05:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: starter problems
Would indicate the problem is with the car , not the starter
How good are your battery cables ( both ) to the engine?
If the full batt power can't get to the starter then the solenoid will operate ( the clicking ) but there is not
enough power to spin the starter over
Check both ends of the cables ; clean , tight, nothing broken
Old Nov 30, 2012 | 07:29 AM
trentonmakes's Avatar
X2
multiple clicking is a battery
check your grounds, connections, wires
make sure you have full charge
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
