Charging problem ...need help
Old Dec 8, 2012 | 07:26 AM
cam.crazy's Avatar
Hi,
I have a Camaro RS-1991 V8 (5.0), recently, I started having charging problem. While the car is idle or driving mode, the voltmeter on the dash says 13+. As soon as I start putting load such as turning on the A/C and headlights + turning signals/CD Player the voltmeter drops to under 12 volts (dash light and the headlights become dimmer) and stays for a while and then it goes back again to 13+ and it keeps doing this every now and then continuously.
Everything back to normal as soon as I switch off everything (A/C, Headlights,..etc)
I have standard alternator (100 Amps) and I also recently replaced the battery with bigger AMPs.
I'm worry that the problem might get worst by time if I keep it this way and I don't feel comfortable driving long distance trips.
Does anyone have an idea what could be the problem?
Old Dec 12, 2012 | 08:09 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Charge Account
Go over the alternator connections to make sure there is no hidden corrosion between the connections.
Also you stated “
driving mode” so we assume the RPM can be above 1200 and the lower voltage still occurs?
If yes to the above have your alternator load tested.
Happy Racing!
After The Fourth Barrel Roll I Lost Control Of The Car
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Slush92RS
Sep 2, 2015 08:56 PM
greenyone
Sep 2, 2015 03:39 PM
