wipers will not work
hi guys its started to rain and i noticed my wipers will not work. i recently installed a vats bypass but i doubt that would have anything to do with it. ive checked the fuse and its fine they just wont turn on at all.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: wipers will not work
It is more than likely the pulse board cracked or corroded solder joint or brush contact in the motor.
Engine: Lb9
Transmission: M20
I posted the schematic so you can check you power and grounds.
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
inspect the inside of that wiper motherhousing thing for water in the circuit board.
Car: 91 Bird
Engine: TPI 350
Transmission: 5-Speed
Axle/Gears: 2.77 posi
Have they worked after you did the VATS? If not then maybe when you were under there you pulled the plug apart at the steering column - unlikely but worth a try. Check fuse. Or buy another motor assembly. It is $70! Jesus
ya see idk if i pulled something when i did the vats because it hasnt started raining here. i should be checking it out on sunday and ill tell you guys what ive found so far thanks for the help.
colton_carlson
Mar 8, 2019 12:21 PM
