Cruise Control Troubleshooting
Old Jan 5, 2013 | 01:06 PM
Panther1's Avatar
Tackling problems one at a time on the '90 iroc and discovered that the cruise does not work, any chance I could get any advice on troubleshooting this?
Old Jan 14, 2013 | 04:25 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Usin Cruisin
The Cruise Module is located behind the right side of the dash IP.
Using a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe the gray wire at the Cruise Module located behind the right side of the dash IP.
When you switch the Cruise to ON, is there power there?
Then probe the
gray wire with a black stripe.
If yes to both, unplug the servo located at the left front of the engine compartment.
Use an ohmmeter to measure across terminals A & C.
The Ω must be no than 55.
Across terminals E & C, same deal.
Across terminals B & D, the Ω must be no than 25.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
