Can you identify these wires?
Old Jan 10, 2013 | 09:46 PM
streetheatz28's Avatar
Car: 88 Sportcoupe camaro
Engine: forged 355
Transmission: th350
I bought a 89 rs camaro that has some rigged up wiring to say the least. It has a carb'd 350 with t-5 transmission and still has the electric in tank pump. I'm trying to get rid of some wiring that isn't needed. I've read that you can delete most of the wiring on the passenger side of the car when you go carb'd. I have 4 14 guage wires and what looks to be 1 12 guage wire all going to the positive battery terminal. I have attached pics and was wondering if someone could tell me what they go to?
Thanks for any help!
Old Jan 10, 2013 | 10:13 PM
Engine: forged 355
Transmission: th350
Re: Can you identify these wires?
Pics didn't attach for some reason but you should be able to see them here>>>>>>>>>>>> https://www.thirdgen.org/forums/memb...166-wires.html
Old Jan 12, 2013 | 11:58 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
To be honest I wouldnt just start cutting all the power wires out. I cant remember what they all do but the easiest way to see what they do would be to disconnect 1 at a time and find out what they do. Personally I did what you wanted to do and it backfired huge on me and I ended up with a new harness because of it. Just my 2 cents tho.
Old Jan 13, 2013 | 07:50 PM
Dan Hubbard's Avatar
Car: K-1 Evoluzione (85 Camaro)
Engine: 5.7L
Transmission: TH700R4
Axle/Gears: stock
Electric fan.
Old Jan 14, 2013 | 10:32 PM
Nunazet's Avatar
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
As one who has done this. I have to say you are approaching it backwards. To remove the right side harness start with the bundle that goes down behind the wheel well by the fire wall and work your way out from there. That way you are working from the known wires to be removed out to their ends around the engine. When I removed mine I believe I only cut one brown wire near the distributor that ran into the other harness from the drivers side. Every thing else I traced from the passenger side to its end. Good luck.
Old Jan 14, 2013 | 11:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Reds are always main power feeds to something , as noted disconnect them one at a time to see what stops working.
The big red is probably the alternator
The removable wires for the redundant EFI are almost always not red
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
