89 gauge wiring help needed
Old Jan 27, 2013 | 12:30 PM
fonzie85's Avatar
Car: 89 IROCZ
Engine: Forged 347 LS1
Transmission: Built 4L60E with 4k stall
Axle/Gears: 4th gen w/ 3.42 gears
I'm looking to put a set of aftermarket gauges in my 89 camaro but have a few questions.
1) When I replaced my trans, the replacement tranys came out of a 91 with electric speedo sending unit. Can this sending unit be used with aftermarget gauges?
2) Can I use all the factory sending units and wiring and just wire the aftermarket gauges off the stock connectors in the dash?
3) Dose anybody have a pin out for the 89 cluster connectors I have found one for an 86. would this be the same for the 89?
Old Jan 27, 2013 | 08:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 89 gauge wiring help needed
Probably need a convertor box
http://www.dakotadigital.com/index.c...126/prd126.htm
Depends .
Some aftermarket gauges only work with their own dedicated sender units
Need to check the specs, in any case you use the stock wiring from engine to the dash and just replace the sender unit(s)
Old Jan 28, 2013 | 01:42 PM
fonzie85's Avatar
Car: 89 IROCZ
thanks for the info. I was hopping I would have to buy a conveter box like. The resons I wanted to switch to an electic speedo is because mine bounces around alot. Is this normal? Also when I hit a decent bump or floor it the speedo goes crazy and there is a loud buzzy/whining noise any body know what this could be?
aslo still looking for the pin out for the 89 gauge connectors.
Old Jan 28, 2013 | 02:16 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I own the older dakota digital dash for camaro's and am putting in the new Dakota Digital system. If your dash is bouncing around, I would change both halves of your cable drive system. I am now sure about the buzzy / whining noise though. The Dakota digital box takes the signal from the Speedo Generator that you install in place of the cable drive sender. It also takes all additional signals from (oil pressure, fuel, brake, turn signals, e-brake, rpm, check engine light, etc.. etc. and puts that to the dakota dash assembly.) I have the pin out's for the 87 IROC but not 89 from the 1987 GM Service Mitchell Manual. I am not sure if they are the same..
Old Jan 28, 2013 | 02:53 PM
fonzie85's Avatar
Car: 89 IROCZ
What do you mean by both halfs of the cable drive system?
Old Jan 28, 2013 | 02:55 PM
fonzie85's Avatar
Car: 89 IROCZ
I was looking at the dakata dash, the one with the actual gauges not the digital read out, do yo like yours? Is it pretty simple to hoot up?
Old Feb 22, 2013 | 04:28 PM
fonzie85's Avatar
Car: 89 IROCZ
I need a pin out for an 89 iroc gauge cluster.... yes i have searched and I have found one for an 86 and 87 but not for an 89. Or as anbody else done a gauge swap in an 89 that can tell me what wires from the factory harness are for what.
I have decided to go with the analog dakota digital cluster but want to make sure I can wire it before I actually buy one.
Old Feb 23, 2013 | 10:31 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
From what I understand they are all the same pin outs as I used a 87 diagram on my 89 iroc when I put in all autometer gauges and used the stock harness. thes are the ones I used for the plugs that plug into the cluster
Old Feb 23, 2013 | 10:38 AM
fonzie85's Avatar
Car: 89 IROCZ
Thanks this will help alot, one more question is which diagram is for which plug?
Old Feb 23, 2013 | 10:47 AM
6SIX6's Avatar
Car: 89 IROC
C1 is on the right side and c2 is on the left. You can always use the wires as they are different colours in different spots
Old Mar 22, 2013 | 07:52 AM
fonzie85's Avatar
Car: 89 IROCZ
I have another question for this swap.... will this guage swap affect my crusie control? or is that completely seperate?
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
