wiper motor problem
Old Jan 27, 2013 | 05:48 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
wiper motor problem
heres my problem, im getting power to the wiper motor and circuit board, but still doesnt not run. removed wiper motor, jumpered it off the battery, motor works. soo the motor isnt bad, i dont think the switch is bad because i have 12 volts goin to the both connectors. now, i did take the cover off, to clean the gears and such. but like a dumba$$ i accidentally spun the black round thing on the circuit board. i put it back to where i think it was. but not %100 sure. can someone give me advice on this other than buying a new wiper motor assembly. oh btw, its an 88 firebird.
Old Jan 27, 2013 | 06:10 PM
shake401k's Avatar
Car: 1986 Pontiac firebird formula
Engine: 383 sbc
Axle/Gears: 4th gen 3.42 posi
Re: wiper motor problem
I had a problem similar once, try this quick test to make sure the wipe case is grounded properly. use a long screwdriver to touch the case to the firewall to ground the case out. do that with it on like high position so you can see.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Cleotiz
Jan 6, 2018 08:56 PM
slade5612
Aug 11, 2015 07:19 PM
