ecm grds
Car: 88 gta
ecm grds
Ok I have the ecm (165) pins and the circuits they attached to...
What I need is a reference as to what circuits the grd wires listed on the ecm pins actually go to? (Espcially the Ecm ground itself.)
Where in/on the vehicle these grds are suppose to go?
I ask because the haynes manual, well that ain't a whole lotta help in that deparment.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ecm grds
Any ECM ground wire only has to go to a good ground point ( generally on the engine ); it is not part of any other " circuit"
Systems controlled by the ECM have a return wire to the ECM that the ECM grounds using the ECM grounds you are looking at
efiguy
Sep 27, 2015 01:30 PM
