91 starting problem
Old Feb 3, 2013 | 11:16 AM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
91 starting problem
hi guys i have no clue what is wrong i have replaced the battery the starter twice jus to make sure. we cleaned the ground wire and checked all the wires. it does not seem to want to start it just clicks and clicks then it will either stop clicking or start. i really wanna solve this issue.
Old Feb 3, 2013 | 12:10 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: 91 starting problem
Sounds like high resistance in one of the battery cables. Need to voltage drop the battery cables to see which one is causing the problem. Anything above .5 volt is considered high resistance.
Old Feb 3, 2013 | 01:40 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
could it be starter realay
Old Feb 3, 2013 | 01:41 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
how do u check the resitence
Old Feb 4, 2013 | 05:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Run a wire from the small terminal on the starter solenoid that has the purple wire on it to your batt.
Touch it (hard ) on the Pos terminal
If the same clicking happens you have the problem mentioned above with your main batt cables.bad , dirty , loose connections usually
If it now cranks over properly, you have a problem with the power from the Ign switch
which includes the switch ,starter relay , P/N switch and the wiring in between.
A bad contact anywhere on that circuit will prevent full power getting to the solenoid so it clicks
Old Feb 5, 2013 | 10:46 AM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
what is this my dad and his buddy is pretty sure this is where im losing the power.
Old Feb 6, 2013 | 09:12 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
what is this
What is WHAT???????
Old Feb 12, 2013 | 06:07 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Hi guys were still having the problem I've replaced the battery starter ignition switch and from what we have seen resietence wise the cables seem fine. Were not sure what else it could be. Also yesterday when I started my car my thermostat was dumped all the way to the right and the Battery gauge was at about 11 the heater also wouldn't turn on as I was driving home I had to slam on the brakes and boom guage went up thermostat worked and heater worked im lost
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
