91 TPI VSS
Car: 1987 Jeep YJ
Engine: 91 TPI 350
Transmission: Getrag MG5
Axle/Gears: D30/35, 4.10
91 TPI VSS
Ive used this forum to answer a ton of questions I have had with my TPI swap from a 91 TPI 5.7L Z28. Well now I have a question that I cant find a specific answer too on the forum.
BACKGROUND: When did the swap in 05 I had a 700r4 and NP207 t-case with mechanical speedo so I never hooked up the VSS and always had an SES code 24. I recently swapped the drive train for a MG5 and an NP241 out of a 98 K1500. I have an Slip Yolk Eiminator kit that has a 40 tooth reluctor ring on it as well.
PROBLEM: I hooked up the VSS wires using the 98 k1500 2 wire sensor. Now when It will start and run fine, but the minute I move It falls on its face and dies. I can disconnect the VSS sensor and drive it all day long, but I get SES code 24. I would really like to have no codes. Any ideas as to what could be my problem?
Thanks Guys!
Thanks Guys!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Facing His Problems
What falls on its face?
The VSS output?
Speedometer?
Code 24 can be set by idling therefore its good to learn to ignore it.
Happy Racing!
If People Drove Any Slower Theyd Be Going Backwards
The VSS output?
Speedometer?
Happy Racing!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 91 TPI VSS
Like NINÅ said the 24 can be caused bye a excessive high idle when the vhicle is not moving caused bye a vacuum leak or throttle blades open to much. you need to use a drac to convert to a 2k optical signal reprogram the eprom to accept the optical signal on the 730 on c6.
Car: 1987 Jeep YJ
Engine: 91 TPI 350
Re: Facing His Problems
The engine dies when i try to move it. I have had the speedometer hooked up independantly without the computer in the wiring loop and it works just fine. I have an autometer gauge so i can run one wire to sig input on the gauge and ground the other. I throw code 24 when I disconnect the sensor. The computer sees the open circuit and throws the code. I have read that I "trick" computer by grounding the yellow sig wire and it wont throw the code, but the computer will think I am not moving and some things will not work right.
Car: 1987 Jeep YJ
Engine: 91 TPI 350
Re: 91 TPI VSS
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: 91 TPI VSS
stock the ECM is looking for a magnetic signal from the speed sensor of 4000 pulses per mile.
the +5V DC square wave signal from your gage won't work without making a change to the chip & it must be a certain number of pulses per mile. i believe one of the links i posted in your other thread may have what it needs to be.
the dying problem answered in your other thread.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Sanjay
Aug 12, 2015 03:41 PM
