90-92 speedo failure after disassembly?
Old Feb 24, 2013 | 08:40 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
So I got a working Speedo to replace my shot one, threw the cluster in and drove the Speedo worked fine, I pulled the cluster apart to swap the odometer for my current one, put it back together and bow its not working. The only thing I can think of was the needle removal/ replacement... Has anyone had a similar issue and found a solution? Or know where I can buy just the Speedo guts? The odometer spins fine but after I swapped the odometer out it started acting like my junk one. The needle isnt hanging up on anything, when I turned the key on it jumped to below 0 and just stayed there.
Definitely frustrated on this one.
Old Feb 24, 2013 | 09:09 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: 90-92 speedo failure after disassembly?
Slight edit: its reading 40 mph off consistently, if I'm going 50 its at 10, 55 is 15 and 60 is 20..... So any insight here???
Old Mar 10, 2013 | 03:31 AM
IROC-ZeeUK's Avatar
Car: 92' Z28
So you got it working but it's just way out?
The only thing I can think of is that you remove the needle again and then replace it so it's positioned against the needle stop, my theory being that the speedo drive returns to the '0' position or thereabouts when you turn the ignition off.
Other than that you'll have to leave the needle slightly loose, find a quiet road and then get the needle in the right place compared to GPS reading! Probably not advisable.....
I dismantled my speedo to swap out my mileage scrolls due to a non working odo/trip. I held the needle against the stop as I prised it off, and then made sure I replaced it in the same position. I road tested mine and it was under reading by around 3-4mph. I guess I could have been lucky.
Sorry if that's not much help, seems to be hardly any info on the 90-92 gauges.
Old Mar 10, 2013 | 09:56 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Yeah I noticed the buzz under 40 and camebto the conclusion that I placed it wrong somehow, I just pulled it off, turned the key on so the gauge returned to true zero and then used my friends cluster as a reference, I took a ton of pictures and painted a spare setbof needles with translucent red paint, I'm gonna make a write up on the disassembly of it all and link various threads for additional info
Elephantismo
Feb 13, 2019 12:51 AM
Fanatic1074
Oct 2, 2015 03:47 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
BBSDesigns
Sep 22, 2015 03:08 PM
