Delay Timer for shift light
Car: 1989 Iroc Z L98
Is there a such thing as a delay timer for a 12 volt accessory? The proform shift light will sometimes freak out in my car, I have it on the ignition right now. I would like to force it to wait 5 seconds or so before powering on.
Thoughts?
Thoughts?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Delay Timer for shift light
ON DELAY TIMER RELAY
Plenty available but they appear to be OFF delay ( supply power after key off ) ,rather than ON delay
This one doesn't state which style
http://www.suntekstore.com/goods-140...3y-2_base.html
This solid state one appears correct operation but a bit pricy
http://www.waytekwire.com/item/75535...N-DELAY-TIMER/
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
you can always run the shift light off the ecm as well.
dhonda200
Aug 11, 2015 11:50 PM
