89 t/a no power to fog lights? help me out
Old Mar 2, 2013 | 11:01 AM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
Alright so im trying to troubleshoot a fog light problem.
i plugged in the fog light to stock pigtails and i get no power to them with either high beam or low beam.
I ran straight voltage to fog and bulb turns on, so fog is good.
I jumpered the red and white wire with the purple wire on what i believe to be the fog light relay, pic below
even after the jumper still no light from fog.
So im ovbiously not getting power assuming im jumping the correct relay connections.
Is there a fuse for fog lights? maybe a combined fuse or something? because i checked the fuse diagram for the 89 t/a and there is no fog lmps fuse like the camaros.
Old Mar 2, 2013 | 05:54 PM
Car: 1986 Iroc-Z
Engine: 355
Re: 89 t/a no power to fog lights? help me out
anyone?
Old Mar 3, 2013 | 02:04 PM
Car: 1986 Iroc-Z
Engine: 355
bump
Old Mar 4, 2013 | 12:28 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Did you check the wiring behind the switch to see if you are getting power there? Its got to be something simple. If I remember correctly the fog lights on a camaro tie into the headlight harness so if the trans ams are the same and your headlights work its not a fuse.
Old Mar 4, 2013 | 10:52 AM
Car: 1986 Iroc-Z
Engine: 355
well i didnt consider the switch itself because the light behind it lights up so i figured it was powered correctly.
Ive been reading that there is a fusible link for the fog lights, does anyone know the location?
the only fusible link i know of is the one near battery and the starter one.
Is there another somewhere?
BRoss99
Aug 10, 2025 05:08 PM
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
