Blinker stick problem
Old Mar 11, 2013 | 12:11 AM
fastrs1891's Avatar
Car: 91 rs vert
Engine: 305 tbi
Hey guys. Hopefully you can help me out with my problem. I got an 86 camaro, and I removed the turn signal stick and as I pulled on it to remove it and it got disconnected from under the dash. I have no idea where it plugs in. It's not like my 92 which has a connector at the steering column. The 86 has a wire that goes all the way down to the bottom of the dash.
Old Mar 11, 2013 | 07:29 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Blinker stick problem
It's for the cruise. If I remember, it plugs into another loose hanging connector. It's fairly small and flat, and it's the only one even remotely like it under there so it should be easy to find.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Jorlain
Oct 8, 2015 01:57 AM
Jk_Under
Sep 2, 2015 10:59 PM
greenyone
Sep 2, 2015 03:39 PM
Bert87
Aug 23, 2015 03:50 PM
