Need gauge light help quick.
Car: 1992 Camaro RS
Engine: L03 V8
Transmission: Automatic
So last night i was attempting to switch out my gauge lights for leds in my 92 rs. I was trying to release the headlight switch when my screwdriver slipped and i hit something. Sparks flew and i blew a few fuses.. i replaced the fuses. and now i got my buzzer back. but still no gauge lights. Please help its my daily driver. I replaced my headlight switch already, but still no luck.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash 4 Cash !
Make sure the dash dimmer control is set at the bright position, then using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe BOTH sides of the INST LPS fuse.
If there is no power both sides check for power on the orange wire at the headlight switch.
Then check for power on the dark green wire at the headlight switch.
Is there power on both wires?
Happy Racing!
I Didnt Jump The Start, The Flagman Was Late
Happy Racing!
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need gauge light help quick.
Are you sure you haven't just got the LEDs in backwards?
Transmission: 765R4
LED Zeppelin
Originally Posted by MrKingrey
blew those fuses I also burnt out those leds.
Do you know the part number of the LEDs?
Happy Racing!
Ghettobird52
Jul 5, 2024 11:18 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
