No start after being in heavy traffic
Old Mar 21, 2013 | 05:31 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Ok this is strange
Twice in the last two weeks I've been in heavy traffic with a hot car, and then shut off the car when I got to my destination. After a few minutes I got back in the car to leave, and it wouldn't start. Starter doesn't turn at all, but the guages do move when the key is turned. It's acting like it would if you tried to start the car without pushing the clutch in.
both times I let the car sit for 10 minutes, and it started up and I drove it home. the car has never done this while cold or in normal driving, only heavy traffic
I've changed the starter, the clutch safety switch and the VATS relay. I'm running out of ideas, anybody got anymore?
Old Mar 21, 2013 | 05:38 PM
usc iroc's Avatar
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
Re: No start after being in heavy traffic
My car did the same thing...I'd climb under it and beat the starter and after about 10 mins it would run. Well it happened at my brother in laws shop one day and when he got in the car he bumped the steering wheel it tried to start. Long story short it had nothing to do with the starter, it was a wire in the steering column that had a bad spot. I beat the crap out of my starter many days and the only reason it would start is I would unknowingly hit the steering wheel which would cause it to start. Anyway...its a long shot but shake the steering wheel and see what happens
Originally Posted by 58mark
Ok this is strange
Old Mar 21, 2013 | 05:41 PM
58mark's Avatar
next time it does it I'll be more than happy to beat the crap out of it
Honestly I have another steering column. Been looking for a reason to install it, maybe this is a good reason
Old Mar 21, 2013 | 05:54 PM
usc iroc's Avatar
Car: 89 Iroc
Engine: 383
Transmission: 700
Axle/Gears: 4.11
I know how crazy it sounds and if it didn't happen to me id be thinking I was . Hope it works out man....I hate chasing ghost!!
Old Mar 25, 2013 | 07:21 AM
58mark's Avatar
Monday bump in case anybody else has any other suggestions.
I'm wondering if something could be overheating the starter, and that's why it works again after 10-15 minutes
Old Mar 25, 2013 | 09:23 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Perhaps the starter does not return to its correct position after starting and is continually turning while the engine is running.
Old Mar 25, 2013 | 10:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
This. Try heat wrap around the starter, i believe DEI sells a wrap velco type shield for starters. Isolate heat from the headers and motor from the starter solenoid and it shouldnt have a problem again
Old Mar 25, 2013 | 08:28 PM
My92camaro's Avatar
I had the same problem and it ended up just being the security chip on the key was bad, I got a new set and it started working perfect again. I'd go to a GM dealership and get the key tested.
Old Mar 25, 2013 | 08:29 PM
58mark's Avatar
Tried multiple keys, it didn't help at all
Old Mar 25, 2013 | 08:33 PM
88gunmetalgta's Avatar
Does it ever click then nothing? This sounds a lot like a loose connection. It would be something to try before replacing the starter. Pull the heavy gauge cable off and clean up the connection, make sure it's tight and you can't wiggle it by hand, and do the same for the engine block ground too.
Old Mar 25, 2013 | 08:35 PM
Nvm, didn't read it all. If you replaced the starter, you probably checked the connection. I know when my starter was getting heat soaked, it would sound like a dead battery.
Old Mar 25, 2013 | 08:41 PM
tbarneski's Avatar
Car: 1987 IROC-Z
Engine: 5.0 TPI
Transmission: 5 Speed manual
Axle/Gears: 3.23 (from a 6cyl car..blah)
Something else to think of would be, if you have tilt steering sometimes they will get loose and "wiggl" around causing the slider that activates the ignition to come out of adjustment. So when you turn the key to the start position it does not make contact. But if you are like me and try to take the cheap way out and get a used starter from the junk yard...or a reman starter from the parts store then I would suspect a faulty starter.
Old Mar 25, 2013 | 10:12 PM
58mark's Avatar
No tilt...
Here. Is what the car does. Picture what happens when you try to start a car without the clutch in. The needles on the dash move, but that's it. No click, no nothing, until it cools down
Old Mar 26, 2013 | 05:24 AM
Well I guess the first thing to do would be to isolate which part of the circuit is causing the problems. If (when the problem is occurring) you can jump the solenoid with a pair of screwdrivers, and it will start, then you have a problem with the ignition switch or neutral safety switch or something. If it still doesn't crank you have another bad starter or a bad connection somewhere or maybe even a bad battery cable.
Old Mar 26, 2013 | 06:53 AM
Beef's Avatar
Car: 89 RS
Engine: Stock L03
Transmission: Stock T5
Axle/Gears: Stock, Too high
Sounds like heat soak. Have headers on it? Its not nearly as likely with stock manifolds. Spend $15-25 on a shield or wrap, see what happens.
Old Mar 26, 2013 | 07:01 AM
58mark's Avatar
100% stock 2.8 v6
So far it's never been down for more than 10-15 minutes, and I haven't tried idling the car for 30 minutes or more trying to replicate the no start condition. It makes it hard to get under the car and test anything if it always happens when it's least convenient.
I'm going to get under there and check the connections for the starter before I drive it again, and if I can't find anything loose, I'm going to exchange the starter for a different one, and put some kind of heat shield on it while it's off the car. There almost has to be something wrong with it that makes it more likely to have this problem than most starters under these conditions, even though it's only a couple of years old
Old Mar 29, 2013 | 01:16 PM
tbarneski's Avatar
Car: 1987 IROC-Z
Engine: 5.0 TPI
My opinion....these cars no matter the engine size have little room in the engine compartment and with a few flaws working together it makes it point right at a faulty starter. My opinion...flaw one : exhaust "y" pipe way too close to starter (heat)..flaw two...engine sits to close to firewall so they put heat padding that reflects the heat from the engine and exhaust back towards the engine/starter (heat). Flaw three...they started making almost all the Chevrolet starters fit various applications which is why you get "shims" with a new or remanufactured starter. Usually the clocking of the starter would be the only difference between them, so it would only stand to reason that if you want your Chevrolet starter to last then buy a brand new starter not a remanufactured and wrap it with a heat shield to prevent the inner windings from swelling and preventing it from working properly until it cools down.
Old Mar 29, 2013 | 01:25 PM
58mark's Avatar
thanks for the help. I just ordered trhe DEI heat shield, hopefully that does the trick
Old Mar 29, 2013 | 02:28 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Eric says...
...and more
Old Mar 29, 2013 | 04:35 PM
Dei doesn't tell you, but the heat shields are conductive! Tape up the hot lug on the starter before wrapping it up! The front side is metallic, and the inside isn't supposed to be, but somehow I ended up with an intermittent short that actually caused a little bit of smoldering and smoke at one point!
Old Mar 29, 2013 | 04:36 PM
58mark's Avatar
wow. thanks... that really sucks!
Old Sep 14, 2013 | 07:11 PM
58mark's Avatar
I couldn't get the heat shield on with the starter in place, so just today I replaced the starter and installed the heat shield while I had it all apart
There isn't a lot of room in there. The heat shield made it a lot harder to install the starter, but using a long screwdriver to line up the holes, I eventually got it
Hopefully this works. the car didn't give me problems often and never left me stranded, but when it wouldn't start it always made me nervous and it was an inconvenience
Old Sep 14, 2013 | 10:36 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
My '88 Firebird did this to me when I first got it. Thought it was the aftermarket security system at first. Changed out the stater and installed a heat shield and it hasn't done this in the past year since. Good luck.
Old Sep 15, 2013 | 09:57 PM
58mark's Avatar
well you warned me... I don't know if this caused the problem, but I have a PROBLEM
https://www.thirdgen.org/forums/elec...e-battery.html
Old Sep 16, 2013 | 09:48 AM
58mark's Avatar
Problem wasn't the shield after all. got it fixed
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
chazman
Aug 22, 2015 02:01 PM
TreDeClaw
Aug 14, 2015 06:58 PM
