How Do Airbag Sensors Work? Sawzall Incident
Old Mar 25, 2013 | 04:00 AM
syoung_2000's Avatar
Car: 1991 Firebird Formula
Transmission: 700R4 to WC T5 swap
Axle/Gears: 2.73 drum to 3.73 PBR swap
I'm doing a swap from auto to manual. I was using my sawzall and realized it had been smacking back and forth against the sensor that's under the console.
There has been no battery in the car for a year.
I'd like to know if my airbags are likely to blow when the battery is connected again.
Do these sensors trigger when there's no power?
Thanks for any info in advance.
Old Mar 25, 2013 | 07:58 AM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: How Do Airbag Sensors Work? Sawzall Incident
From what I remember years ago when first installed on cars: The sensor is basiclly a magnetic ball. When the ball detaches from the sensor, is when the air bag deploys. I would assume you have not had enough impact to dislogde the ball from making contact with the sensors and if you did I am sure they are back in place now.
Old Mar 25, 2013 | 12:20 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Id pull the fuse to be safe or plug the battery in now and hopefully nothing happens. Or replace the sensor with one you know hasnt had a sawsall incident
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Streetstuff
Sep 7, 2015 09:23 AM
squiggy2
Aug 9, 2015 09:30 PM
