VATS question...help!
Old Apr 11, 2013 | 12:20 AM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I'm in the middle of an analog to digital dash swap and my car came with VATS equipped with the analog harness. This digital dash harness I got was from an 89 with no vats option (I assume this because there is no connector that looks like the one from my analog harness that plugs into the passkey module) so what I'm wondering is if everything will still work normally if I'm using a non vats harness on an originally vats car with the chip in the key and wiring on the steering column. Thanks!
Old Apr 14, 2013 | 01:19 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: VATS question...help!
It may work, but I have a feeling your vats module isn't going to be happy, if you're swapping all the wiringiI ddon't see why it won't work, the signal goes from the tumbler to the module to the ecm (in basic words) and if it worked for the previous car it should work in yours
Old Apr 14, 2013 | 01:32 AM
Axle/Gears: 3.45
Thanks for the reply. Technically wouldn't I be able to cut all the wires on the vats connector and have it connected to the module and just have to the connector that plugs into the ignition tumbler plugged in and splice the enabler wire that goes into the ecm and leave the rest of the wires that go into the rest of the harness?
Old Apr 14, 2013 | 03:35 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Well 89 SHOULD have vats, so I would splice that connector into the new harness and do the resistor trick on the plug. Or you can ground a wire on the vats relay which will leave the security light on but you can pull the bulb out, or there's the option of a custom prom with no vats
I would just do it and see what the result is, you have multiple avenues to choose from if need be
Old Apr 14, 2013 | 05:20 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That is only going to make the starter work ; will do nothing to bypass the fuel disable signal to the ECM
Old Apr 19, 2013 | 07:17 PM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
You could get one of these to solve your problem?...http://www.ebay.com/itm/360222657937
Old Apr 19, 2013 | 07:40 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Those are some expensive resisters and a unnecessary relay.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
