Power cuts off with the use of anything
Old Apr 18, 2013 | 05:00 PM
System1's Avatar
Car: 1988 iroc camaro
Engine: forged 383 tpi
What could my problem be? One day i go to crank my car and (nothing). Not uncommon, so i check and change all the usual culprits. Here are my symptoms. If i go to crank the car i get the tick tick sound the first few trys. The last few the power kicks off as if the battery is dead and then comes right back seconds later. If i step on the brake the power cuts off, if i turn on the headlights the power cuts off. Sounds like a weak battery, but this is the second battery and both work on other cars. Any other suggestions?
Old Apr 18, 2013 | 10:04 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: Power cuts off with the use of anything
I would check all battery connections for a bad connection. Make sure all connection are good at the starter and at the battery. Check the fusible links at the starter also. You have a power wire(like the main cable from the battery to the starter)that's not able to handle the load. I would also check the ground cable for a bad connection at the battery and where its bolted to on the engine. You have a high resistance problem in the wiring. Most likely in one on the 2 main battery cables.
Old Apr 19, 2013 | 07:17 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
try cleaning the battery terminals.
Old Apr 19, 2013 | 07:21 PM
hotrodln's Avatar
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I agree with the other guys! battery terminals first, then make sure it's fully charged....as in leave a charger on it for a few hours.
Jeremys87
Jul 14, 2022 09:08 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
soarestransam
Sep 1, 2015 04:00 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
