TPS Voltage vs Resitance reading,
Old Apr 19, 2013 | 05:31 PM
Astrozombie81's Avatar
Car: 88 Iroc Z
ok so I turn on my car, bam shoots up to 2k rpm and stays. i set the idle air as per post. i then go to set my TPS voltage. at pins A & B with throttle fully closed i read 4.56vdc to wide open the voltage goes down. i pull it put the ohm meter to it, resistance increases as throttle increaces this would mean voltage would decrease. opposed to the tps voltage starting at .54 and increacing to over 4vdc. that would mean resistance is decreasing as throttle is increasing. I have drove this car with this tps on and it ran fine then out of no where the idle sky rocketed. bad TPS? what would make it be backwards. pin A black wire, pin B grey, pin C blue. Any ideas?
Old Apr 19, 2013 | 05:37 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPS Voltage vs Resitance reading,
The grey wire is the ecms 5v reference the blue wire is the feedback to the ecm. The blue wire gets set to .54v at idle. The black wire is the potentiometers ground. The throttle is increased the resistance goes down from b to c. If your looking for a bad tps do a sweep looking for a glitch preferably with a analog vom.
Old Apr 19, 2013 | 05:44 PM
Car: 88 Iroc Z
well from b to c using a digital mutimeter, the resistance is staying at 429 ohms through full range of motion.
Old Apr 19, 2013 | 05:46 PM
Engine: Lb9
Transmission: M20
Sorry the resistance to ground
Old Apr 19, 2013 | 05:52 PM
Engine: Lb9
Transmission: M20
Set the tps using the black and blue wire
Car: 88 Iroc Z
well the resistance either dosent move or goes up slightly, from a to b, a to c. the local parts store has one in stock ill pick it up and compare resistance with mine to see the difference. altough i dont know the resistance range of the pot it seems bad to me.
Old Apr 19, 2013 | 05:53 PM
Car: 88 Iroc Z
tired, voltage starts at over 4vdc and barley changes from idle to wot.
Old Apr 19, 2013 | 06:02 PM
Engine: Lb9
Transmission: M20
That's no good, I can't remember but think the full resistance of the tps is 5-7k
Old Apr 19, 2013 | 07:27 PM
Car: 88 Iroc Z
thanks for the help, 2 seconds to fix with a good part, 8 hours to determine which part. gotta love it.
Old Apr 19, 2013 | 07:37 PM
Engine: Lb9
Transmission: M20
You remember that learning experience
Old Apr 21, 2013 | 09:56 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
FWIW, the blue wire should be in the middle, i.e. on pin B.
If A is ground, you should be reading 0 V on it, not 4.56. Are you sure you got the pin labels right?
TBRays98
Sep 6, 2015 05:05 PM
FormulasOnly
Sep 6, 2015 10:42 AM
scotrans am
Sep 5, 2015 04:26 AM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
