3wires to go please
Old Apr 28, 2013 | 09:52 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
3wires to go please
My new project roared to life this morning...now for the detail work. I am lousy at understanding schematics so if someone in simple terms can get me going it would be greatly appreciated. I have the single terminal oil pressure sender(top of block) the harness has the 3 prong that goes above the oil filter which wire do I need? #2 my alt. has a 2 prong(red and brown) can't find where brown went (plug removed entirely and not sure where it was)and are both red wires hooked to hot at all time? #3 I have a water temp sender in driver side of block what color wire would make it work? Thanks for any help.
Old Apr 28, 2013 | 11:12 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: 3wires to go please
You'll probably need a new oil pressure sensor. As for the others, I'm not sure.
Old Apr 28, 2013 | 11:37 AM
Joe Tag's Avatar
Oil sender: tan is sender signal, orange and grey are for the fuel pump switch
Temp sender signal wire is green
Alternator: red wire goes to the terminal closest to the passenger side, brown goes to the right of it facing the engine
Old Apr 28, 2013 | 11:54 AM
Joe Tag's Avatar
Best image I could find to help calrify that Red is correct, brown would go where the black is
Old Apr 28, 2013 | 12:20 PM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
Thanks Joe.I have the wires hooked to the Alt. just checking to see if both red are hot always or key on and don't know where bn wire from alt goes(probably to guage) not sure how to find where it was on harness. Temp and oil working
Old Apr 28, 2013 | 01:09 PM
Joe Tag's Avatar
Best I can tell , the brown goes to the volt guage, you're going to have to dig into the engine harness and find it unfortunately
Ozzie'Z28
Jun 14, 2013 08:10 PM
IrocZ'85
62
Mar 23, 2011 11:55 AM
grdpdr305
Nov 17, 2010 09:02 PM
eddie89TA
Nov 23, 2003 06:43 AM
