signals and wipers quit working while fog lights on
Old Apr 28, 2013 | 02:19 PM
onebadredz28's Avatar
Car: 91 firebird vert
Engine: 305 tbi
hey i was driving around in the rain and wanted to use my fog lights. well i turned them on and i noticed my wipers getting slower and slower until the stopped work and same with my turn signals. as soon as i shut off fog lights everything was fine. works great when lights are on just not when fog lights are on. anyone have any ideas. Thanks!
Old Apr 29, 2013 | 07:53 PM
Engine: 305 tbi
Re: signals and wipers quit working while fog lights on
Update. Now with headlights on wipers and signals dont I want to work. Maybe a flasher?
Old May 6, 2013 | 07:34 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Flash Dance
Not a flasher problem due to the fact your wipers are also slowing.
Make sure it’s not a battery voltage problem by using a test instrument grade voltmeter on the battery while you’re having the problem.
If the voltage is OK then make sure all the associated wiring’s connections are clean and tight, as you are losing voltage somewhere.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Old May 7, 2013 | 08:30 PM
Engine: 305 tbi
Hey thanks! Just found it. Bad ground on driver side under the air filter intake. All works again. Thanks!
Old May 8, 2013 | 04:22 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Any time you have a multiple system failure with added current and they share a common ground, check it first. Chances are, the grounding strap/hardware has rusted out or corroded which is exacerbated by wet weather.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
