Two items - cruise control and info center buzzer
Old Apr 29, 2013 | 08:32 PM
87 Rag Roc's Avatar
Car: 1987 IROC Convertible
Transmission: 5 Speed
Long story short...car has been garaged but occasionally started. Took it out for a run to just see how everything felt. Now the cruise control does not work.
Since I hooked up a new battery there is a constant buzz from the DIC box. Ive looked those threads up and suspect a bad box and luckily have a replacement.
But may there be a connection between that and the cruise control not working.
It always has in the past. Now it seems that when I put my key in the column that the tone starts to change. The signal stalk with the CC is on the opposing side.
Should I expect an issue in the steering column? Or is that just happenstance that they are near each other?
Any opinions are appreciated...love being on this board! Cheers!
Old Apr 29, 2013 | 08:51 PM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: Two items - cruise control and info center buzzer
The cc switch on the turn signal arm is a very common problem. Check the fuse first! You can find the lever on eBay ect. Check YouTube on how to replace.
Old Apr 29, 2013 | 09:27 PM
87 Rag Roc's Avatar
Will do, the fuse was in the back of my mind.
Problem just occurred so I didn't get to troubleshoot at all. Figured I'd give a shout out since I was online.
Much appreciated.
Keep on Roc'n
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
toones
Jan 6, 2016 06:00 PM
Bull86
Aug 10, 2015 05:43 PM
