Rear Hatch motor Problems...
Old May 1, 2013 | 08:35 PM
Eric0840's Avatar
Car: 1988 Iroc Z
I replaced the motor for the hatch lid and still nothing happens... it can lock and unlock even if I use the button on the center console it will unlock with no problems but the motor does nothing and I have no idea why....
This Is my last try at this cuz I can only find ways of how to replace the motor which ive done, but cant find anything on what the rest of the assembly is to see if that is the issue. like when I took out that black chip thing I noticed a switch is on the side of it. like which way should it be switched up or down whats its purpose? I think it has to be down cuz otherwise I couldn't fit it back on the motor. and when you use the key to unlock the trunk u can see that a metal piece contacts something electrical I tried to pull it out but the clip wont budge and I wont want to break anything. I know this was long and pointless but I need help...
Old May 1, 2013 | 08:41 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: Rear Hatch motor Problems...
I think that's the limit switch your talking about. Have you checked or replaced the relay?
Old May 1, 2013 | 08:49 PM
Eric0840's Avatar
Car: 1988 Iroc Z
I haven't checked because I don't know what or where it is cuz like I said I cant find anything anwhere on what all the parts actually are I wish in that video by 1aauto they could've said what all those parts were and see if that was the cause
Old May 1, 2013 | 10:50 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
https://www.thirdgen.org/tech/hatchpulldown.pdf
http://www.top-downsolutions.com/hat...-pull-down-uni
The hatch release and the pull-down unit are on two different circuits and fuses. Did you determine you have power at the red/white stripe wire that connects to the blue wire?
Take a look at the Tech Article that I posted here on TGO years ago under the General Repair category. If you have power and a good ground wire, then problem could be either the striker-sensing switch or reversing switch. I posted the link to the reversing switch, but both are available (along with ALL the parts to repair these pull-down unts) on my web site.
Lon Salgren
Old May 4, 2013 | 05:14 PM
Eric0840's Avatar
Car: 1988 Iroc Z
what chop can I but the relay at? gm part number not showing up any where tried looking at car quest site but im not sure they got it iether
Old May 6, 2013 | 12:03 AM
lonsal's Avatar
The black box on top of the motor is the reversing switch. There is another switch just in front of the latch attached with a single hex-head screw called the striker-sensing switch. How it is supposed to work is when the latch releases the hatch hook the striker-sensing switch opens starting the up cycle. When the pull-down unit reaches the end of with the up cycle the reversing switch is tripped by a one of two tabs on the side of the lift rod. That reverses the direction the motor travels when the circuit is started again by the hatch hook latching in the latch and pressing the striker-sensing switch.
If either switch is bad it will cause the symptoms you describe.
Lon
Old May 24, 2013 | 11:19 PM
Eric0840's Avatar
Car: 1988 Iroc Z
well so far ive replaced the motor brand new and the relay brand new and im pretty sure I hear power to it when I have the key on for a while I thought it was the fuel pump but still nothing is happening but I guess now I need to replace the striker switch right? thanks lonsal. if that's not the ticket hopefully youll know something I dont
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
