Rear hatch solenoid Amp draw 1984 Firebird
Old May 10, 2013 | 12:51 PM
corlando52's Avatar
Car: 1984 Firebird SE
Engine: 2.8 L
Transmission: Automatic
Does anyone know the amperage draw of the rear hatch solenoid? I want to put another switch on it and need the amperage rating.
Thanks!
Chris
Old May 10, 2013 | 01:23 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Re: Rear hatch solenoid Amp draw 1984 Firebird
Measure the resistance of the solenoid, then use Amps=Volts/Ohms to determine the amperage required to overcome resistance.
Old May 11, 2013 | 11:06 AM
corlando52's Avatar
Engine: 2.8 L
Thanks! I didn't think of that. I found a SPST relay with 40Amp contacts, so I think I'm good.
Thanks again!
Chris
Old May 11, 2013 | 01:16 PM
corlando52's Avatar
Engine: 2.8 L
Can I assume that if contacts are rated at 240V 10A, then at 12V they can theoretically handle 200A?
Chris
Old May 13, 2013 | 04:03 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Silly Assumer
NO
10 amps is safe max for that relay.
Happy Racing!
I Didn’t Wreck Last Week, The Track Moved
Old May 13, 2013 | 04:31 PM
corlando52's Avatar
Engine: 2.8 L
Re: Silly Assumer
Thank you. Then it would be each contact is rated at 10A. The relay is DPDT, so each throw can handle 10A, correct?
Chris
Old May 14, 2013 | 04:21 PM
NINÅ's Avatar
Transmission: 765R4
Silly Assumer
CORRECT
Happy Racing!
I Didn’t Wreck, The Track Moved
Old May 15, 2013 | 10:43 AM
corlando52's Avatar
Engine: 2.8 L
Re: Silly Assumer
Originally Posted by NINÅ
CORRECT
Happy Racing!
Thanks! You've been a great help!
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
