HELP PLEASE! NO ACCESSORIES WORKING
Old May 19, 2013 | 03:59 PM
scagz2.8l's Avatar
Car: 1988 camaro rs
Engine: 2.8l
Transmission: automatic
so from what I understand everything under the fuse "acc" is my dome light, head unit, power locks, cigarette lighter ,and headlights. my car has always been a little scary wiring wise but haven't had a real problem until recently. sometimes none of the accessories would work at all then if I hit a bump the right way they would turn back on. I also had a problem with my head unit constantly restarting and this would happen for a about a day then stop every once in a while. lastly my dome light has always flashed sometimes random and usually when I hit a bump. now my all listed above completely stopped working. that makes me unable to drive my car at night because of my headlights because it is my daily driver. I am guessing it is a loose connection somewhere so if anyone has any ideas where I should look or any input at all please reply. thanks
Old May 19, 2013 | 05:37 PM
Scott85's Avatar
Car: 91 B4C
Transmission: auto
Re: HELP PLEASE! NO ACCESSORIES WORKING
The headlights aren't part of the ACC fuse, unless you mean the interior lights. Do you have an aftermarket head unit ? Sounds like someone spliced into the ACC circuit and there's a loose connection.
Old May 19, 2013 | 06:40 PM
scagz2.8l's Avatar
Car: 1988 camaro rs
Engine: 2.8l
well my headlights aren't working right now. and I baught the car and the guy had an aftermarket headunit prior to selling it so he could have gotten his 12v from there I just used the wire sitting there. the guy did some sketchy stuff with his wiring. the last time I turned the car on the acc were on then I tried to turn on the headlights and the acc turned off and the headlights didn't do anything
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Fronzizzle
Aug 17, 2015 02:52 PM
ZsTransAm
Aug 11, 2015 07:30 PM
