Not Battery, Not Alternator?
Old May 20, 2013 | 01:09 PM
champster's Avatar
Car: 87 Camaro
Engine: 2.78 V6
I recently got an 87 Camaro 2.8.
My Voltage gauge was low, so, based on the hum, I changed out the alternator. (Gotta love cars where you on change a car part, on lunch, in dress clothes ;-) )
Problem went away for a while, then came back.
I changed the battery.
It seems like I have a drain on the system somewhere.
My AC/Heat blower, radio, turn signals, all drop the voltage needle more.
Even my Tach wiggles with the turn signals, etc.
Any idea where to look next?
Old May 20, 2013 | 03:45 PM
champster's Avatar
Car: 87 Camaro
Engine: 2.78 V6
Re: Not Battery, Not Alternator?
OK, Maybe not drain.
Maybe it is just not charging.
I found a thread to follow and meter some points.
Since I changed the Battery and Alternator, I know those wires seemed fine.
I didn't realize that it went through the starter first. I'll check those terminals and wires.
Old May 20, 2013 | 07:50 PM
champster's Avatar
Car: 87 Camaro
Engine: 2.78 V6
I get 12.1 volts at the battery.
If I start the car, I get 9.5 volts. (didn't check all that was turned on)
I assume the alternator is doing nothing.
I disconnected the + terminal and I get 0.3 Volts between terminal and alternator housing.
As for the other 3 wires.
Big red is same as battery. No (on my meter) resistance from Battery +
White (second wire) is battery voltage when IGN is on.
Brown wire does nothing. Not sure where it goes.
I don't see a Battery dummy light on any of the bottom dash lights, nor a light on the gauge.
Is my problem an alternator (which is new, and I wonder if I even had to change it or if I had this same problem the whole time) ?
Is my problem the trigger wire? I still don't know if the white or brown is trigger.
Old May 20, 2013 | 08:22 PM
champster's Avatar
Car: 87 Camaro
Engine: 2.78 V6
I'll have to doublecheck, but I think this is the replacement I put in.
http://econtent.autozone.com:24999/z...2/0/86/523.pdf
It says I can use I or L. I'll doublecheck, but "I" had battery power.
Old May 21, 2013 | 02:20 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
Good way to test the alternator for proper operation is a full field test- on these internally regulated alternators, there are normally three terminals- the main battery positive, ignition positive, and the field terminal. They are labeled B, I, and F. Turn the vehicle on, with a multimeter set to read volts at the B terminal of the alternator and a good ground. Take a voltage reading prior to starting the test. Turn the headlights on and a/c if equipped, and use a jumper wire to contact the B terminal to the F terminal on the alternator and read voltage output. Do not keep the jumper wire in place any longer than required to take the reading, this could damage your charging and wiring system. You should recieve a voltage reading of between 15 and 17v. If the alternator passes the full field test, the problem lies elsewhere, I have seen bad ammeter and battery warning lights that have caused this problem.
Old May 22, 2013 | 06:27 AM
champster's Avatar
Car: 87 Camaro
Engine: 2.78 V6
What else would have to left connected during the test? (Ex. Does B still need to go to battery AND Alt when I jumper it, or just battery?)
My Alt. has 5 connectors.
BAT on back and a connector with 3 wires in it. There is 4 terminals on the Alt side of that connector. S I L P
I think S is what you mean by B? It connect back to battery.
BAT connects to Battery also, via Starter.
"I" is for direct IGN power (internally registered)
L is for a battery light, which I don't have.
I do have a voltage gauge, which I just fixed a few weeks ago. I wonder if that was connected to "L" and is not working any more. When starting, the needle would peg out the meter. Problem was, no peg, so it would get stuck behind the bezel. I just put a small strip of black duct tape between the face and the bezel to keep it from getting stuck. The gauge works fine now.
With the limited testing so far, I know it is not a drain and is definately the Alternator putting our nothing.
Old May 29, 2013 | 03:02 PM
champster's Avatar
Car: 87 Camaro
Engine: 2.78 V6
Holidays and rain.
I haven't made it back under the hood yet.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
