Need help with v6 oil pressure gauge wiring
Old May 27, 2013 | 07:00 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Im almost ready to drop the 350 into my car for my swap. My car was originally an auto v6 efi car. I completely removed the v6 computer harness on the passenger side of the car, but now i realize i cannot find the connector for the oil pressure gauge sender unit. Does anyone have a diagram showing where under the dash the 2 wires are located? Im assuming the connector was apart of the computer harness, which is why i cannot find it. It was a two wire connector.
I looked through wiring diagrams for the engine and body wiring, but i couldn't find anything.
Old May 27, 2013 | 09:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need help with v6 oil pressure gauge wiring
Originally Posted by mgg4591
cannot find the connector for the oil pressure gauge sender. It was a two wire connector.
On any harness, the wires " under the dash" would go to the gauge cluster connector
and on the harness in the engine bay the OP gauge only uses 1 wire
A 2 wire unit on the engine harness is a switch (OPSU ) for the fuel pump backup
Later cars have a single 3 wire unit on the engine that combined the OP gauge ( 1 wire ) and the OPSU ( 2 wires ) in one unit
If you are reading your circuit diagrams correctly you will see the wires at the OPSU on the engine are org and tan /bk
Old May 28, 2013 | 06:42 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Um, he's looking for the gauge wire, which is solid TAN and comes out of the connector by the brake booster. It should be in E5. It's one wire.
Old Jun 3, 2013 | 07:38 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Thankyou, exactly what i was looking for. I just need help with one more, where are the wires for the coolant temp gauge? Are they part of that harness as well, or were they in the v6 engine harness? thanks.
Old Jun 4, 2013 | 04:31 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Same connector, but in F5... Only one wire, and it's also a ground through the sending unit. Yes, these were in the engine harness.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
