How to open hatch with no power and no key
Old Jun 5, 2013 | 11:02 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
So my motors pulled and I gotta get crap out of the back of the trans am. My motors pulled. I tried hooking a battery to te power and I grounded it ad nothing. What do I do ? Thanks
Old Jun 5, 2013 | 12:09 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: How to open hatch with no power and no key
Not sure about trans am's but the camaro has key lock to enter the rear also. Use that if it's present, it'll work without power.
You will be able to open it if:
1) there is a battery in the car
2) if the auto shift console is connected and in park or neutral
3)the power motor is of course still working...
Old Jun 6, 2013 | 02:24 PM
I have the key but the lock is jammed.
Old Jun 6, 2013 | 02:32 PM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
if i understand correctly you can if it has it pull out the rear cargo light. then you can look inside the compartment and pull on the cable it should unlock the rear hatch .
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
Randomtask2
Aug 13, 2015 01:57 AM
