How do I get power without an enine?
Old Jun 8, 2013 | 04:41 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
So I just picked up an 87 IROC roller and was wondering what do I need to hook up to get power to the car. Basically I want to have the ability to roll the windows up/down and open the hatch remotely without tearing out the interior.
I have a battery and the pos./neg. terminals are there along with all the wiring, but when I installed the battery nothing happened.
Old Jun 8, 2013 | 06:49 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: How do I get power without an enine?
Not exactly the right way to do it, but...
Get a bolt and a nut, and bolt all of the terminals that are where the starter SHOULD be together. That's where the dash power comes from (and from there, almost everything else except the fuel pump and ECM which are on a separate junction block).
Just make sure to cover the connection quite well with SOMETHING.
Old Jun 8, 2013 | 08:57 PM
jharrison5's Avatar
Car: '87 IROC
Ok... now the question is which wires am I looking for? The hot from the battery is the wire in the center of the pic, and I think the wires with the bolt attached to them next to the exhaust is what I'm looking for correct?
Attached Thumbnails How do I get power without an enine?-20130608_203423_zps88a99807.jpg
Old Jun 10, 2013 | 05:24 PM
Engine: 2.7L V6
Axle/Gears: 4.41
The wires you need to connect to the battery cable are the ones bolted to the bellhousing in the pic. You will also need to bolt the negative cable to something solid on the frame for ground.
Old Jun 10, 2013 | 08:50 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
There are two solid red wires that go to the main bulkhead connector by the brake booster, chase those two and connect them to + on the battery, and then ground the negative side to the chassis.
Old Jun 10, 2013 | 09:50 PM
jharrison5's Avatar
Car: '87 IROC
I put the battery in the car Saturday and hooked up the group of wires attached to the bolt that goes to the starter and got nothing.
I will try to locate those wires coming out of the bulkhead tomorrow after work and see if that does the trick.
As you can tell wiring is not my thing lol! I have been using my 86 IROC as a guide, but since it is carbureted and not tpi, I'm having some issues.
I don't plan on putting a motor in the car for some time and there will only be a battery in there when needed to im looking to do this the safest way possible.
Old Jun 15, 2013 | 10:26 PM
jharrison5's Avatar
Car: '87 IROC
Thanks Z28ricer for the heads up on the location of those wires! I didn't get the hatch to open, but I was able to get the windows up so I could remove a door lock. Now if I can get a key made from that lock I will be set! If not then I don't know what I'm going to do LOL.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
