85 hatch stuck (no key)
Old Jun 11, 2013 | 06:19 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Hello, I own an 85 IROC, without the electric hatch pull down.
A few weeks ago my hatch release switch decided it didn't want to work anymore, +12 volts are being read at the switch terminals so I know it's getting power.
I have a subwoofer box in the well, making it extremely hard to access the hatch mechanism, but I can access it somewhat.
When I bought the car it came with some keys, only one of the keys actually did anything (start the car), the others were useless seemingly (wouldn't lock/unlock the doors, wouldn't unlock/lock the ttops or hatch). So I can't get in the normal ways.
Thank you *very* much for your help, I appreciate it sincerely.
Edit: I did some searching, the only info I can find is on the hatches with the pull down motor.. I can't find any info on the non-electric hatches.. some people said use a flat head screwdriver to get it open, but I can't figure out where to do that at.
Old Jun 18, 2013 | 06:19 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Waaxing Philosophically
Originally Posted by WaaX
……..12 volts are being read at the switch terminals so I know it's getting power.
However make sure the switch works.
Jump the switch to determine.
When jumping the switch do you hear a *click*?
Happy Racing!
If My Engine Has An Illegal Part, And The Inspector Doesn’t Hear It, Does It Make A Sound?
Old Aug 1, 2013 | 11:56 AM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Re: Waaxing Philosophically
Happy Racing!
Sorry, almost forgot that I made this thread.. When I say "I know it's getting power" I mean at least at the switch. I did try jumping it yes, did not hear a click (I touched the two wires together).
Old Aug 3, 2013 | 04:30 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
Re: 85 hatch stuck (no key)
I was able to get it open.
I took my center console out mainly to clean everything..
The relay was bad I think, I took the black wire coming out of it, and applied 12v to it, Bam! hatch open! So, I kind of bypassed the relay, lengthened that black wire, and have it tucked away but if I need to open the hatch all I have to do is untuck it and apply 12v.
Old Aug 3, 2013 | 04:47 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
I just pulled the lock cylinder out of my driver's door and had some keys made at my local locksmith. Cost me $27 and a bit of time.
1992Z28!
Nov 19, 2015 07:33 AM
Johnoooooo
Sep 22, 2015 08:55 AM
Denricci22
Sep 18, 2015 09:02 AM
