cranking problem..please help
Old Jun 13, 2013 | 01:01 AM
chevyman559's Avatar
Hi guys i have a 91 rs. 5.0. I pulled out and replaced block. When i was ready to start her up; she wouldnt make no noise or cranck. I replaced battery since it was been sitting for a few years. I replaced battery terminal cable goin to the starter. I checked starter switch. Fuses. Safety swich and still no cranck. I could turn on the hea lights i have 12 volts on the red cables. But only on the purple cable goin to the starter i have 4.8 volts. Please anyone has an idea what could be the problem.
Old Jun 13, 2013 | 07:40 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: cranking problem..please help
Check the ignition switch at the column with a meter, you should see 12 volts while cranking, after that the next thing in line is the clutch safety switch above the pedal if you have a manual, or the neutral safety switch if its an auto located in the center console, I know for manuals the wire going in is yellow and the wire going out is the purple wire, can't say for certain on the neutral switch for an auto but I believe its the sane deal, whichever you have check the yellow wire for 12 volts. Then check the purple for 12, if it goes in as 12 and doesnt come out as 12 you've found your issue. I believe there's also a risible link that causes this same issue but I'm not totally sure on that
Old Jun 18, 2013 | 06:09 PM
I checkec the voltage on the two cables ( yellow and purple). I only get 5 volts on purple and 10 on the yellow. Im wondering if is the key switch.
Old Jun 18, 2013 | 06:12 PM
i forgot to mention when i turn the key. Fuel pump doesn go on.
Old Jun 18, 2013 | 07:23 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by chevyman559
I checked the voltage on the two cables ( yellow and purple). I only get 5 volts on purple and 10 on the yellow. .
Jumper the two wires to bypass it and see if that changes anything ; might have high resistance causing the voltage drop
Old Jun 19, 2013 | 10:29 PM
827-snyWA's Avatar
Car: 88camaro
Engine: carburated 350
Transmission: th350
Axle/Gears: 3.73 posi
[quote=chevyman559;5583575]i forgot to mention when i turn the key. Fuel pump doesn go on.[/quo
it's the switch, you cant close the solenoid with 5volts. take it out and test the continouity just to be shure. and test the one goin back in too.
Old Jun 21, 2013 | 10:51 PM
Ok guys so i checked the igniton switch and i have 12 volts on the yellow cable. I also checked the yellow and tan/ white cables and have 4.75 volts. I belive is the starter relay and still no cranck . What can i do next
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
skinny z
Oct 5, 2015 06:23 PM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
