Wiring power locks ????
Old Jun 19, 2013 | 08:40 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so im trying to rewire my power locks wiring since the po just cut the wires an left them i figured out the lock an unlock but where does the black wire hook up to i have like 3 black extra wires an i dont know what they are for so far i have the power windows rewired, an power mirrors recconected correctly just need help with the power locks
Old Jun 20, 2013 | 10:38 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
Re: Wiring power locks ????
According to my Haynes manual, each lock switch has a black wire from the unlock position to the door lock relay assembly.
Old Jun 23, 2013 | 08:33 PM
Engine: LR4 4.8
Ok so where is the lock relay located would it be located under the dash i didnt even know the power locks had a relay
Old Jun 24, 2013 | 05:09 AM
Car: 1988 GTA
Engine: 400 CI
IIRC, on my car it is behind the drivers side kick panel.
Old Jun 30, 2013 | 07:48 PM
Engine: LR4 4.8
Can u take a picture of the lock relay and show the wiring coming out the relay so i can see which ones are the one that ground the circuit
Old Jul 1, 2013 | 04:58 AM
Car: 1988 GTA
Engine: 400 CI
Today is raining all day but if it clears up tomorrow I will. I know it is hard to see because it is between the outside body panel and the inside body panel. Here is a picture of the wiring diagram so maybe that is all you need. I tried to scan it but it was pretty much unreadable. Let me know if you still need me to take a picture tomorrow.
Attached Thumbnails Wiring power locks ????-door-lock-wiring-009
Old Jul 7, 2013 | 09:08 PM
Engine: LR4 4.8
Ok so it must be screwed into the kick panel metal ill try to follow the wiring an see if it will lead me to the lock relay
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
ZsTransAm
Aug 11, 2015 07:30 PM
