Wipers work fine but stop high on the windshield
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Hi guys,
So I'm solving the little electric troubles I'm getting with my T/A, found out the radio and wiper problem came from the ignition switch. So I've rebuilt it and they both power up fine now. I'll buy a new one on my next order.
Now I'm getting a weird problem with the wipers, they work as they should in all positions, except the wipers stop in the highest position instead of stopping at the base of the windshield.
I was thinking maybe the linkage is set up wrong, but why would they move correctly then ?
Also the driver side wiper goes too far and wipes the pillar as well.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Walk In The Park
When you turn off the wipers do they stop instantly, or do they move into the area you describe the same way each time?
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
Happy Racing!
1992rs/ss
Jan 31, 2025 05:10 PM
